qik1 Silver Donating Members 2,720 Member For: 16y 8m 23d Gender: Male Location: Loitering in SEQ Posted 27/06/09 01:33 PM Share Posted 27/06/09 01:33 PM used to run rich as believe it or not. It was funny it just wouldnt make anymore power no matter what was done. It actually made a touch more power on the 17psi tune I had at the same time but the other was quicker. Once we put the plenum on it changed power delivery & we cant stop it making power as the end result shows. Just silly. Link to comment Share on other sites More sharing options...
GR8XR6 ANGEL EYES Silver Donating Members 1,683 Member For: 16y 6m 12d Gender: Male Location: SE Suburbs, Melbourne Posted 27/06/09 01:47 PM Share Posted 27/06/09 01:47 PM (edited) qik1 what plenum are you running? Forget that just spotted it! LOL! Edited 27/06/09 01:48 PM by GR8XR6 Link to comment Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 16y 8m 23d Gender: Male Location: Loitering in SEQ Posted 27/06/09 02:22 PM Share Posted 27/06/09 02:22 PM I have to add when changing to an aftermarket plenum you more than likely wont see similar results as we did with mine. I dont have an explanation to why such a big jump in power. I can more than feel it as far as seat of pants feel & it was on the same dyno obviously. Every car as most of us realise are different & react differently to different mods. It worked for me & cant recommend the product enough but if you do fit it & you dont see a stupid/ridicleous results dont be irritated or frustrated. I was over the moon after the first retune when it made an extra 10+kw on 3 - 4 less psi. This is probably the best advertisment for changing to an aftermarket plenum. that's the type of results that you should hope out of a product. Even though some say you dont need them til your looking at over 400 any less stress that's put on the eng is a bonus in my opinion. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 9m 8d Gender: Male Location: Victoria Posted 27/06/09 11:36 PM Share Posted 27/06/09 11:36 PM I'd go either Nizpro or Process West because the Plazmaman item requires you to drill out the holes in the lower section. Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 2m Gender: Male Location: SoR, WA Posted 28/06/09 02:16 AM Share Posted 28/06/09 02:16 AM (edited) I dont think many people know this as it is not advertised. Edited 28/06/09 02:17 AM by Adrian6T Link to comment Share on other sites More sharing options...
Fryer of Tyres Boost Addict Member 198 Member For: 16y 6m 22d Gender: Male Location: Belcompton Posted 28/06/09 03:19 AM Share Posted 28/06/09 03:19 AM Anyone know off hand how much a NIZPRO plenum is ??(as it's not advertised on their website) Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 4m 26d Gender: Male Location: Mildura Posted 28/06/09 03:45 AM Share Posted 28/06/09 03:45 AM better spool up ok, minimal though...., better power @ less boost.... who cares? there is a limit of pwr the stockos turb will go anywayz, and it will do it with the standard plenum.You all there Sausage tits??A Plenum will allow the tuner to make similar power and in most cases MORE power with LESS BOOST, therefor taking strain off the rods and making for a safer motor.Yes the stock plenum will goto 400, choking its ass off and ringing your turbo's neck to do it risking your motor. Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 2m Gender: Male Location: SoR, WA Posted 28/06/09 07:02 AM Share Posted 28/06/09 07:02 AM Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 18y 20d Gender: Male Location: QLD Posted 28/06/09 07:52 AM Share Posted 28/06/09 07:52 AM I'd go either Nizpro or Process West because the Plazmaman item requires you to drill out the holes in the lower section.And once you have fitted a Plazmaman Plenum you would never return it to standard again so drillingthe lower manifold out to fit it is not any problem.Fitting the Plazmaman plenum on my near stock BA along with HDI Cooler resulted in dropping my ET from 13.9 @ 98mphto 12.9 @ 116mph with fuel surge problems in a manual.I choose the Plazmaman plenum over the PW as I preferred the angle of enterance as it doesn't by pass thefirst port as per the PW does and it has better enterance into each port where as the PW has raised venturiwhich would disrupt the flow into the runners, plus the plazmaman looks cleaner.that's my option and why I made my choice.I have seen many PW car make power though and also Nizpro Cobra.So it is a choice each will need to make on there own as they all make good power required for good street & Track performance. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 9m 8d Gender: Male Location: Victoria Posted 28/06/09 07:58 AM Share Posted 28/06/09 07:58 AM And once you have fitted a Plazmaman Plenum you would never return it to standard again so drillingthe lower manifold out to fit it is not any problem.There's plenty of people who return their car to standard when it comes time to sell it. Link to comment Share on other sites More sharing options...
