Bad Apples Donating Members 110 Member For: 19y 7m 9d Gender: Male Posted 23/04/09 12:15 AM Share Posted 23/04/09 12:15 AM Could someone let us know where the ASL trigger comes from. I want to be able to turn the amps on when the factory head unit is switched one. at the moment I have the cig lighter, which is triggered with the key. also it would be cool to turn the amps off when car is on but the head unit switched off.I thought that maybe the power for the lcd backlight could be used to trigger a transistor, it might now work direct as it's dimmable, so obviously the voltage can vary.Anyone please?I have no dramas with removing the head unit I have already done the pre-amp out mod.Cheers. Link to comment Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 17y 14d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 23/04/09 12:32 AM Share Posted 23/04/09 12:32 AM Easy Solution.... KEEP IT WITH THE CIG LIGHTER, OR GET URSELF AN AMP WITH A HIGH PASS AUTO TRIGGER SENSOR!The factory amp never had a 'trigger wire' that I am aware of (after reading what all the other guys have said - haven't bothered to play with the F6 stereo as yet myself).So unless you want to build a little relay and screw around with where to mount it, blah blah, or pull the whole head unit apart again (not advised) then just leave it or get auto triggering amps!You could whack a little 12v switch on your cigi lighter trigger switch if you like as well, this would act as a manual on off switch... But again - if you can be bothered. Link to comment Share on other sites More sharing options...
skradz Member 44 Member For: 17y 1m 14d Gender: Male Location: MELBOURNE Posted 23/04/09 06:11 AM Author Share Posted 23/04/09 06:11 AM hooked it up to the cig lighter all works fine now... cheers for the help guys Link to comment Share on other sites More sharing options...
bafpvgt Member 9 Member For: 19y 8m 8d Posted 23/04/09 08:12 AM Share Posted 23/04/09 08:12 AM From Memory, there is a spare blue plug under the dash that is an accessory for mobile phones kits. I used the plug and all works fine. Link to comment Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 17y 14d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 23/04/09 11:57 AM Share Posted 23/04/09 11:57 AM Link to comment Share on other sites More sharing options...
romanooo Member 31 Member For: 16y 1m 16d Gender: Male Location: SHEPPPP VIC Posted 24/04/09 12:01 PM Share Posted 24/04/09 12:01 PM hey bro where'd you get your fibreglass sub boxes from? Link to comment Share on other sites More sharing options...
skradz Member 44 Member For: 17y 1m 14d Gender: Male Location: MELBOURNE Posted 27/04/09 10:05 PM Author Share Posted 27/04/09 10:05 PM I got the sub box of ebay.... Link to comment Share on other sites More sharing options...
