SLVRXRT Member 28 Member For: 19y 5m 9d Gender: Male Posted 21/04/09 11:15 PM Share Posted 21/04/09 11:15 PM Hi Guy’s, I had a set of atomic valve springs , X-Force front section and also a custom tune done last week. The custom tune was set to run 13psi max. Driving around last night, I noticed that as soon as you put the boot in, it spike’s to 14psi momentarily then comes back to and holds 13psi all the way.Is the1 psi spike anything to worry about? It also does it on my 11 psi tune, spikes to 12psi then drops back to 11psi. Link to comment Share on other sites More sharing options...
ETM Member 1,194 Member For: 17y 10m 15d Gender: Male Location: syd south Posted 22/04/09 12:00 AM Share Posted 22/04/09 12:00 AM That is typical behavior for an internally gated turbo, the tuner SHOULD know this and will have your tune set so that if the fuel system reaches it limit at say 15 psi that your tune will run at say 13 psi. This allows 1 psi for the anticipated boost spike and 1 psi safety margin.From my experience 14 psi is fine and the fuel system should be able to cope with it no problem, have you changed your fuel filter lately? Link to comment Share on other sites More sharing options...
SLVRXRT Member 28 Member For: 19y 5m 9d Gender: Male Posted 22/04/09 12:20 AM Author Share Posted 22/04/09 12:20 AM Yeah, filter was replaced around 2 months ago, and the car is also is running green top injectors. Link to comment Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 15y 11m 1d Gender: Male Posted 27/04/09 11:31 PM Share Posted 27/04/09 11:31 PM My 10psi generic tune peaks at 14psi before trailing back (stock injectors too). Had it on a dyno to cheak the a/f and it was fine at all revs. The only problem is, my standard clutch doesn't like the spike and will slip in 4th,5th,6th gears when it comes on boost. I'm sure a 1psi spike will be very safe. One day I'll get a custom tune... anyone want to sponser me? Link to comment Share on other sites More sharing options...
