  • Member For: 21y 9m 19d
Well, I had some time to think today, and came up with some questions:
1. If an intercooler is too large - would this create lag due to longer time
required to pressurise the system? Assuming cooler is large enough to cool
the air down sufficiently in the first place.
2. Does the BOV plumbed back into the intake system on a manual car reduce
lag by dumping boost back into the system, reducing time required to pressurise
the system for the subsequent gear?
Sorry if these are silly questions... :spoton:
https://www.fordxr6turbo.com/forum/topic/56969-general-turbo-questions/
  • Member For: 18y 1m 20d
1. yes it will definately effect the time it takes to see boost pressure in the manifold.
2. to achieve this you must plumb the air back into the compressor wheel at a very specific angle to ensure the flow of air onto the compressor wheel actually makes it spin and not the opposite. You can test the optimum angle with an air gun.
  • 3 months later...
  • Member For: 17y 2m 18d
Sorry if these are silly questions... :sleepystuff:
I reckon you would get less lag if you took the bov off and blocked up the whole where it was.
