Diy Rca To Rca
Azid Rush
  • Member For: 18y 9m 10d
Firstly speaker cable is not the correct way of making a RCA. Use a multimeter to make sure the interigty of the cable is ok, eg no shorts etc.
You can also run a RF signal out of your Foxtel box into an analogue tuner, which only requires 1 cable, RG59 or RG6.
  • Go Pies!!!
  • Member For: 16y 11m 11d
Az, basically it is just a signal path switch.
AV switch box - signal RCA in -> push button/switch -> signal path out... Its basically a 1 IN -> 3/4/5 whatever OUT.
Range from about $50 up for decent ones...
But if there is Coax out on the back of the Fox Box - just use that... much cheaper, and much easier... Parents whole place is done in this form and works simple and easy...
Only down side is all TV's will be watching the same channel at the same time (if tuned/switched to that channel on the TV), and channel changing requires getting off your butt and going into the room where the box is located. (Option to get around this is a IR repeater however)... :thumbsup:
Ill PM some other info to you!
If you go the RF way you can send the IR signals down the Coax. If you go to Dick Smith or similar you will find Foxtel have a IR kit for your Foxtel box.
IMO a composite signal sh*ts all over the RF but each to there own.
  • Moar Powar Babeh
  • Member For: 19y 4m 5d
Get one of these:
http://www.altronics.com.au/index.asp?area=item&id=A3126
I just installed cabling to 3 rooms so i now i have 4 rooms on the one foxtel box.
I also install I/R remote repeaters so i can control the box and my AV amp from which ever room
im in
The signal strength is so good, I had to install 3db atenuators to reduce the signal strength
to stop ghosting and picture drop out.
Guest newl
  • Guests
I used to use a set of wireless A/V transmitter/receiver pair purchased from trickie dickies. Worked a treat.
As others have said though, if you have coax out, use that. Otherwise, take a stab at the distribution amplifier solution Luke mentioned.
  • Bored Member
  • Administrator
  • Member For: 22y 2m 14d
What about using AV senders and if set up right you can even use your remote
:stupid: 's quickest easiest and best solution I've used and your not confined to one spot in a room if you decide to move it.
Set the oldmans place up with these in a couple of rooms with one a good 30ft from the box in a shed down the backyard with no signal drop...
  • blind leading the blind
  • Member For: 16y 4m 17d
the av senders work great just make sure ya dont get the same frequency as your cordless phone otherwise it becomes a big pain in the arse
