Shaking Vibration! Argggg Help Pls...
stockxr
  • Banned
  • Member For: 17y 4d
hey all, this week I had a few things put into the t, including...
-fuel pump
-valve springs
-42lb boshies
-and a cooler, and pipping
the power gain is awesome, I didn't hit peak due to a shagged stando cat, but I'm not fussed about that as its an easy fix, the thing that concerns me is..... after the tune, when the car is in drive and at a standstill for example at a red light the car shakes like a NASA air shuttle, if I chuck it in N the shaking ceases but if I put it into reverse it starts to shake again.while I'm driving it doesn't seem to be there. I have no idea what it is, the tuner reckons that it could be mu exhaust hitting something but its to vigorous for that.
has any one had this problem after tuning there T, ant thing will hep thanks guys.
regards adrian
  • Formerly EGOBFXR6
  • Member For: 16y 11m 21d
Is it idling very low at a standstill? That sometimes causes bad shudder...
Any other funny problems? If it wasn't doing it before, then it has to be something to do with the tune then. It's probably not coils if it was fine befroe.
You're best to take it back to the tuner mate, and get him to sort it out...
Dan
  • Banned
ye at a stand still in drive its sitting at abot 500-600 rpm, then wen its in N it sits about 1k-1100 and at that stage there is no vibration, do you recon its got any thing to do with the way the spark plugs have been gapped???
  • Hey guys, Tab is here... Oh i feel sick
  • Member For: 16y 8m 3d
maybe with the new power it couldnt handle it, iv been around falcons all my life and those symptoms are a common sign of a busted mount
  • Formerly EGOBFXR6
Yeah mate,
It's idling too low then... My bet would be that you may need to have your plugs re-gapped. Vixen makes a good point as well.
Good luck mate,
Dan
  • Formerly EGOBFXR6
I don't think it's something you can fix yourself...
I'd wait til Vixen comes back. He'll have the answer. :thumbsup:
I'm sure your mechanic/tuner could sort you out mate.
Dan
