Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 11m 17d Gender: Male Location: Brisbane Posted 09/10/09 09:08 AM Share Posted 09/10/09 09:08 AM (edited) repating what was mentioned above, sorry Zap.Scotty Edited 09/10/09 09:19 AM by Kimberley Scott Link to comment https://www.fordxr6turbo.com/forum/topic/56804-d2-racing-brakes/page/6/#findComment-941458 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 20d Gender: Male Location: Sydney Posted 09/10/09 10:56 AM Share Posted 09/10/09 10:56 AM Yeah I have had this argument many times and people forget that it is the little rubber tyre that does most of the work, but let people think they are right for a short time.As for RAP1D's view on the Chinease stuff, he is very correct. As they tool up and steal designs and processes, they can make a very good or sometimes better knockoff. The to4z you mention are still substandard, you only need to ask APS and they massive list of annoyed Twin Turbo owners in the USA that have been stung by a bad batch of chinese to4z that APS tried to palm off as the real thing.I am still however reluctant to put my faith in anything "cheap" that could take my life or the life of my family. Link to comment https://www.fordxr6turbo.com/forum/topic/56804-d2-racing-brakes/page/6/#findComment-941483 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 15d Gender: Male Location: Sydney NSW Posted 09/10/09 11:24 AM Share Posted 09/10/09 11:24 AM The fox body's, they were Mitsubishi TDOx rip-offs, but yeah, same deal... atleast they wern't gambling with poeples brakes. Link to comment https://www.fordxr6turbo.com/forum/topic/56804-d2-racing-brakes/page/6/#findComment-941496 Share on other sites More sharing options...
RSK Member 340 Member For: 17y 9m 21d Gender: Male Posted 09/10/09 11:52 AM Share Posted 09/10/09 11:52 AM I'm with zap on this one...Big brake setup will NOT reduce your stopping distance from a one off stop as standard brakes have enough power to lock the wheel.Not from 200kmh's + they don't. Link to comment https://www.fordxr6turbo.com/forum/topic/56804-d2-racing-brakes/page/6/#findComment-941510 Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 18y 2m 18d Gender: Male Location: Sydney Posted 12/10/09 10:05 PM Share Posted 12/10/09 10:05 PM Well never tried but I would imagine they could struggle from 200+ to 0 but that comes back to heat dispersion, the reason they would struggle is because they would get too hot. Nothing to do with this fancy physics theory that bigger rotors stop you quicker. Link to comment https://www.fordxr6turbo.com/forum/topic/56804-d2-racing-brakes/page/6/#findComment-942538 Share on other sites More sharing options...
Jact New Member 13 Member For: 16y 10m 24d Posted 09/11/09 12:32 PM Share Posted 09/11/09 12:32 PM I'm backing Sprjenkins here, the larger surface area of bigger brakes has everything to do with reduced braking distances, sure heat, pad friction, etc. affect this but what he said is without a doubt true and factual!Go read the Vehicle Standards Bulletins, especially VSB 14 (NCOP5). Was told by the licencing center here in Perth that it contains everything you need to know about the legality of modifications done to your vehicle.Vehicle Standards BulletinsAlso Winstor's post is quite good as the NCOP's state:Fitting disk brakes that are not a manufacturer’s option - requires certificationAlso interesting to note that it mentions International Standards & Association Standards for braking systems (ie. rotors, callipers) are recognised in Australia as compliant! Link to comment https://www.fordxr6turbo.com/forum/topic/56804-d2-racing-brakes/page/6/#findComment-952337 Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 16y 11m 13d Gender: Male Location: Melbourne Posted 12/11/09 01:02 PM Share Posted 12/11/09 01:02 PM Sprjenkins, rubbish. Your theory forgets that the limiting factor is grip. This is not like braking a farking train or applying pressure on a belt sander .We have seen stopping distance tests in magazines bear this out. The main advantage of large rotors is heat dissipation as well . You are correct with regards to more pots means more even application of pressure.Stopping rotational motion is the same principle no matter what the function. Big brakes will reduce your stopping distance no matter what tyres you are running, its exactly like braking a train or a belt sander. When you brake you are trying to convert kinetic energy into heat energy. If your maximum grip level is, lets say an arbitrary figure of 100, then if you can convert a greater amount of kinetic energy through greater friction without locking up the wheel or exceeding the maximum grip level then you will stop quicker.As someone else said, braking is about energy conversion, energy is converted through the tyres friction on the road and the pads friction on the rotor. If you hold the former constant while increasing the later you wwill stop quicker. Link to comment https://www.fordxr6turbo.com/forum/topic/56804-d2-racing-brakes/page/6/#findComment-953348 Share on other sites More sharing options...
