FPVF6355 Member 128 Member For: 14y 4m 29d Posted 13/03/13 08:57 PM Share Posted 13/03/13 08:57 PM I thought about it last night, Instead of a fibreglass tank and check valve, a bladder might be better and easier.The tank in the boot has a small hole in the fill cap to allow water flow to the pump. A bladder would just get smaller until empty and should prevent the need for a check valve. Could fit under spare wheel. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1371472 Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 6m 7d Posted 14/03/13 12:14 AM Share Posted 14/03/13 12:14 AM Great idea, I guess I'll have to drink all the wine first Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1371546 Share on other sites More sharing options...
FPVF6355 Member 128 Member For: 14y 4m 29d Posted 14/03/13 09:18 AM Share Posted 14/03/13 09:18 AM Does scotch come in a cooler bag ??Had a look around, plenty of 1.5ltr, 2.5ltr, 40ltr, 400ltr 10000ltr, no fricken 5 ltr bladder bags. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1371705 Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 6m 7d Posted 14/03/13 11:08 AM Share Posted 14/03/13 11:08 AM In Scotland....I think you can get Scotch in anything you want.2L, 4L and 10L but not bladders are not cheap.http://www.ebay.com.au/sch/I.html?_trksid=p3984.m570.l1313&_nkw=10l+bladder&_sacat=0&_from=R40 Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1371752 Share on other sites More sharing options...
Weeman Member 72 Member For: 18y 9m 1d Gender: Male Location: Parkes NSW Posted 14/03/13 12:02 PM Share Posted 14/03/13 12:02 PM I did a DIY kit, uses a manual switch on the dash and a foot switch on the accelerator pedal that turns on at about 80% throttle. Haven't got any data to prove if it does anything but I enjoyed making it. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1371775 Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 6m 7d Posted 14/03/13 11:18 PM Share Posted 14/03/13 11:18 PM Nice 1 Weeman. I thought about pedal activation but went for a pressure switch instead. I think pedal activation would be just as good but maybe a little harder to install. What did you use for a spray nozzle? On 14/03/2013 at 12:02 PM, Weeman said: Haven't got any data to prove if it does anythingNow that I have a gauge that gives me intercooler temp in and temp out, I hope to be able to provide concrete stats as to what the water spray does and does not achieve. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1371847 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 6m 1d Gender: Male Posted 15/03/13 10:19 AM Share Posted 15/03/13 10:19 AM this has made me feel so guilty. I had mine all plumbed and wired, except for the earth wire. Its been practically finished since before summer. damn I'm a lazy ass sometimes. I bought the 4x4 and its been getting all the love :(I'm going to finish it tomorrow night for sure, and I'll post back some info. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1371988 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 6m 1d Gender: Male Posted 17/03/13 04:20 AM Share Posted 17/03/13 04:20 AM all working now, fairly pleased with the results although haven't played with the trigger setups. at the moment its triggering above 3psi.I might do above 0psi AND TPS > 80%. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1372345 Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 6m 7d Posted 17/03/13 05:15 AM Share Posted 17/03/13 05:15 AM Your setup looks very professional. Glad you have it up and running now. Are you using a pressure switch? Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1372359 Share on other sites More sharing options...
FPVF6355 Member 128 Member For: 14y 4m 29d Posted 18/03/13 12:03 AM Share Posted 18/03/13 12:03 AM Ended up using a tyre inner tube for the water bladder.You can buy a fitting adapter used to fill tractor tyres with water. got one made up at pirtek hoses.I've got it under the spare wheel, hose runs out through spare wheel well drain hole.works really well, holds about 15 ltrs.will take photos once I get the temp controller. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/7/#findComment-1372563 Share on other sites More sharing options...
