Water Spray
Panda Eyes
  • Member For: 18y 8m 6d
Dalts had the nozzles for free back in Jan as his post suggests. They are premo nozzles but think you would need a decent pump to atomise the water through them as the pump that comes with the water/meth kit is 4.5lt/min at 220psi.
Better off buying this kit like I did while the dollar is still good-My link
Ray076 and I got ours for Aus $360 delivered each as we offered US$270 each for them so try even lower I suppose!
I agree to get decent intake temp drop that kit is the way to go!!
I got the stage 2 back when the dollar was crap!!cost around $700 still good value in my books.
cheers lee
  • 1 month later...
  • Team Grandpa Qualified
  • Member For: 19y 11m 19d
Couple of notes on some of these comments....
1/ evaporative cooling relies on air movement to create temperature drop, and
2/ every degree cooler is 3 horsepower gained.... add up a 10 degree variation and it's substantial - same as driving your T on a cold winters night vs 1pm on a summers day.
Worthwhile project when done the right way. Great info guys.
  • 2 months later...
  • Member For: 17y 6m 1d
ok soooo having a good crack at doing this to my ute .. :) if it works - coool, if not oh well im bored and want a project .. ha
ok today go given off a mate his REAR windscreen washer bottle off his 300zx , that he does not use any more .. its pretty cool it has 2 built in pumps and a low level switch bulit in .. so today after work I just quickly mounted it in the back right near the drain holes to run all the lines , if it works good might mount it under the tub .. its not wired or lines run yet ..
I also mounted and wired up my lil control pannel I made to fit in the dash .. its alloy and iv machined ingraving into it , has a big XR6T and then " water intercooler sprey" in it .. plus "ARM " and 'ON" .. runs 2 switch's and 2 lights ..
one switch will turn it on and off .. and the other will only turn the pump on when its in boost . im running a boost pressure switch's I got from ebay .. all in all should work well .just waiting to get a inline fuse and RELAY plus work out my water lines .. few pics ...
post-12564-0-24486000-1302325202_thumb.j
post-12564-0-87120600-1302325213_thumb.j
post-12564-0-98066600-1302325275_thumb.j
post-12564-0-89248400-1302325334_thumb.j
post-12564-0-73868200-1302325373_thumb.j
I think any type of water on it will help plus a 50/50 meth mix ... evos and wrx's run them standard (washer bottles) .. and on a super crisp cold night spreying water/meth on the cooler will drop temps right down .... iv got a intake charge temp gauge built into my MSD dash hawk so il be able to let ya know how it works ..
Edited by SLY6T
  • 1 month later...
  • Member For: 13y 11m 17d
  • Gender: Not Telling
looks the goods sly6t.
I used to run a gtr at the drags that I sprayed/soaked water from a hand held spray bottle with ice in it onto the core,pre run.
Even after the run, the intercooler was still very cold on the outlet tank of the cooler.
Free hp, are good hp. :turboboink:
Edited by james333
  • Member For: 17y 10m 26d
Im not going down the road of misting the cooler, this is what ive gone for, I havent fitted it yet its just staring me in the face until next weekend
http://www.snowperformance.net/product.php?pk=8
  • flame magnet
  • Member For: 16y 8m 16d
plus wont they prohibit you from running if there are any liquids leaking from the car?
  • Member For: 21y 4m 29d
These are the kits we go for- http://www.ebay.com.au/itm/Snow-Performance-Stage-1-Water-Methanol-Kit-20001-/120721085729?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c1b899521
You can offer them $270us and they'll take it straight away also so save yourself even more money. Only thing I had to make that I forgot to buy from the kit was the alloy bung for the nozzles- http://www.snowperformance.net/product.php?pk=52
I have made brackets up for my bottle to mount on the passenger just behind the light with my rapids IC kit so I will take pics once I finish it, if ever!
