Bellato Donating Members 2,713 Member For: 14y 7m 28d Posted 10/05/13 10:48 PM Share Posted 10/05/13 10:48 PM I wonder how well something like this would work on a stock FG cooler just to get you to 300 or even max the turbo out Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/12/#findComment-1388187 Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 10m 16d Gender: Male Location: South West QLD Posted 10/05/13 11:15 PM Share Posted 10/05/13 11:15 PM Lol.. I saw blokes with water bottles which were 50/50 water and metho spraying their crossovers at willowbank one day.. We're adamant it got em 0.2 off the ET.. Dude you're gonna do a burnout.. Any heat soak in the crossover will happen when staging.. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/12/#findComment-1388205 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 26d Gender: Male Location: Sydney Posted 11/05/13 01:33 AM Share Posted 11/05/13 01:33 AM On 10/05/2013 at 10:01 PM, sexual harrassment panda said: Awesome work kroozin, how much all up for the kit?Thnx, about 150 but I made it up myself 1 Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/12/#findComment-1388243 Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 6m 7d Posted 08/06/13 11:13 AM Share Posted 08/06/13 11:13 AM Well, I'm still having the syphoning issue. I fitted one of these http://www.ebay.com....=item43ba34f32fIt slows down the syphoning a bit but does not stop it. Takes about 4 hours now to empty my 4 litre tank. Before installing this valve it took about 30 mins.Looks like I may have to investigate installing a solenoid. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/12/#findComment-1396772 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 26d Gender: Male Location: Sydney Posted 08/06/13 04:29 PM Share Posted 08/06/13 04:29 PM That's farkt dude. How us yours setup? What pump are you using, etc? Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/12/#findComment-1396812 Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 6m 7d Posted 09/06/13 12:54 AM Share Posted 09/06/13 12:54 AM Hi Kroozin,Yeah mate it sucks the big one. At least when it gets sorted the thread should help people who run into the same issues.1. 4 litre washer tank with built in washer pump (VDO) in the boot. 2. One way valve about 10cm from the tank (4mm tubing)3. Tubing runs under the car with the fuel lines.4. The new spring loaded valve in the engine bay about 60cm from the sprayers5. 2 plastic garden mist sprayers (half circle). One for the top half of the intercooler and one for the bottomBefore installing the new valve the water would start syphoning out as soon as I filled the tank.Since installing the new valve the water does not start syphoning out immediately. However once the pump has been activated it begins syphoning and empty's the tank.I think I will need to install a solenoid like this one: http://www.ebay.com.au/itm/121108003351?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649I assume I can get fittings to suit the 4mm tubing. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/12/#findComment-1396844 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 3m 10d Gender: Male Location: Gladstone, Queensland Posted 12/06/13 03:33 AM Share Posted 12/06/13 03:33 AM Water spraying the cooler is half arsed. If you going to do it....http://www.snowperformance.net/stage-2-maf-boost-cooler.htmlFull boost with the smaller 375ml jet, no quench, 19*intake temps and over 5 degrees of extra timing. You can run the smaller jet with not have to increase timing at all.Ive since stopped using it since I went to E85 but one day might see if there are any advantages or running both. I doubt there will be and will more than likely go back to a small jet just to keep the intake temps as low as possible. Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/12/#findComment-1397582 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 26d Gender: Male Location: Sydney Posted 12/06/13 04:26 AM Share Posted 12/06/13 04:26 AM Your right but I thought I'd give this ago anyway. It cost me a fraction over 100bux and it works quite well. Obviously I haven't needed to retune since the new edition either. I have fitted this just assist in keeping iat's down (which it does) yet not run into any dramas should I run out of water since it has not been tuned with it. A meth kit would be pretty cool but so would a 0.7 front comp cover or other bits and pieces when looking at $$$ vs gains. The water spray isn't exactly the right answer but its def. not the wrong answer either. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/56695-water-spray/page/12/#findComment-1397592 Share on other sites More sharing options...
