  • flame magnet
  • Member For: 17y 1m 7d
has anyone experimented with a water sparay onto the cooler to help with temps on warm/ hot days?
https://www.fordxr6turbo.com/forum/topic/56695-water-spray/
  • Member For: 19y 1m 3d
Do a google search mate, they used to be big on rex's... I've still got an mrt water spray controller off a rexy for way back, they work well, just gets annoying filling up the water tank over and over... worth doing though if your keen DIYer
https://www.fordxr6turbo.com/forum/topic/56695-water-spray/#findComment-860258
  • Member For: 19y 11m 16d
A couple of articles from Autospeed on the subject.
Clicky
https://www.fordxr6turbo.com/forum/topic/56695-water-spray/#findComment-860262
  • Member For: 20y 10d
I had a MRT auto sprayer controller on my rexy a while back and loved it, you could notice the difference. I actually bought the parts to put on the F6 but never got around to doing it.
Russ
https://www.fordxr6turbo.com/forum/topic/56695-water-spray/#findComment-860296
  • Member For: 17y 3m 20d
I had one on my car when I bought it. Was tee'd off the BOV and when ya hit 3psi would squirt water thru a 3 jets setup. Was adjustable to different psi. I found I annoying as they used an old washer reservoir so its as noisy as when you spray water on your windscreen but doing it constantly meant having to fill it up every few days. Real pain.
https://www.fordxr6turbo.com/forum/topic/56695-water-spray/#findComment-860533
  • Member For: 18y 2m 10d
I had waterspray on my WRX and I think it worked.. I ran it two ways over the years.
One off a hobbs switch when it hit 7psi and one manual switch in the cabin.
Some Jap Spec wrx's / sti's had blingin water bottle in the boot that held 20 odd litres or something. Another mate bought a highly modded wrx straight from japan and that had jets built into the front bar for the FMIC!
https://www.fordxr6turbo.com/forum/topic/56695-water-spray/#findComment-860779
  • Member For: 17y 10m 22d
im setting up a system soon as well , iv got every thing from hobbs switch to pump il mount to my ute rails under the try and check valves .the only thing I need to get it all running is a tank . been looking on ebay I want sum thing that will look good sitting in the corner of my ute tub..
Edited by 6L_ETA
https://www.fordxr6turbo.com/forum/topic/56695-water-spray/#findComment-861492
  • ANGEL EYES
  • Member For: 16y 11m 1d
Can you keep us posted as to what parts you are using to make this diy setup? What trigger mechanism are you using?
:beerchug:
https://www.fordxr6turbo.com/forum/topic/56695-water-spray/#findComment-861524
