Attempt To Run Nines(eventually)
dalts
  • Member For: 18y 8m 12d
hi guys,
over the next few months will be attempting to run low 10,s high nines at the track in street trim,already have a manifold and wastegate have decided to go a gt4502 (aka t51r)at this stage just wondering for people in the know!what size exhaust housing size would be best suited.will be at the track by the end of winter,any help would be appreciated
thanks lee
hey scotty long time no hear,yeah thought id be happy running a 10, who am I kidding have the urge to go alot faster lol,have to catch up next dyno day when your free
lee
  • www.australianflag.org.au
  • Member For: 19y 6m 22d
Yes mate I will do eveything in my power to be there. Good thing is my new depot is 5 minutes from Elite Autos. So should see you guys more often.
Scotty
  • Member For: 20y 8m 12d
hi guys,
thanks lee
Mine is the same turbo, I run a 1.05 exhaust housing, and I think this is good balance between size and boost off the mark.(I have a 6boost manifold though)
I have a 3000rpm stall, and can stall it up on the brake.
you wont have any trouble making power.
because of the stock motor, I have not wound the power over 444rwks, 21psi) and the 10.4 @132mph was at 19psi 404rwks
David
thanks david,I thought you were running one of those turbos.1.05 sounds like the best option as the car will still see alot of street use aswell!im running a 2800 stall no transbrake and speaking to peter from gilroys he said try it with that stall first should pick up more rpm with the extra torque that the engine will make!what is the max psi these turbos make? as we will be pushing it to the limit
thanks for the input
lee
  • Member For: 15y 10m 16d
A GT45 and T51R are two different turbo's.
The T51R uses an old school TA51 turbine.
The GT45 has a GT45 Turbine.
They also have different housings.
Be sure to order the correct turbo you are after.
Edited by Ricky N
thanks ricky n
definatly getting the bb version,was originally going to go with a t04z set up but I know id end up wanting more,will know this week what turbo and specs ill be going with
lee
  • Member For: 18y 8m 19d
Mines got a 1.05, but its a GT4596R... fairly streetable so for drags it could even be the next size up maybe.
They are spose to be good all day at 30psi plus.
