  • Member For: 17y 11m 4d
If you want a decent boost in power try bigger injectors, high flowcat, remove center muffler, F6 intake with K&N filter and tune. See how you go. Maybe set you back 2.5k
  • Member For: 14y 6m 17d
Thanks Dillz,
Probably start with the intake for now....anyone know where to source these? Ford, wreckers? I read somwhere you have to cut a hole in the existing air filter box/panel to fit the 2nd F6 snorkel, any pics or guides of where exactly its meant to go?
Also, excuse me for my noobiness, but I won't need a tune just for a CAI will I?shocked.gif
Edited by Dush73
  • Phantom Menace
  • Member For: 14y 8m 20d
every so often theyre on eBay for about 60 bucks from memory, a hole is required to be cut for it. No you wont need a tune for a cai but you may notice on cold nights a little overboost.
  • 3 weeks later...
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 8m 24d
Wouldn't worry about the spark plugs until you get a custom tune as the tuner may ask you to use Iridium spark plugs with a 0.8mm gap. Other thing is on the topic of fuel, if you do go for a custom tune, they will tune for particular RON - so it is possible to get a 91 RON, 95 RON and/or 98 RON tune. If you custom tune for 98 RON and use 91 RON I am told your engine will ping (never tried to put 91 RON in yet). But if you have your XCAL3 or equivalent handy, you can always flash back to stock if you can't get the RON your custom tune is designed for.
:bowdown:
Gaz I'm pretty sure they come out of the factory tuned to 95 but you should try and run them on 98 yeah? DO NOT stick 91 in them ya tight arses, lol.
Just changed my spark plugs today(NGK iridium), cleaned throttle body & boost valve & noticed the top hose of the boost valve had a cut in it....I guess that would mean less boost? I'm hoping that was the issue I had(mentioned it in another post where when cold ran well....I guess all cars do..lol....but when warm under load was spluttering/pinging).Had to silicone it for now......hope she screams come tomorrow 6am :D
Don't like the price of Premium 98, but releuctant to use anything less......using Shell atm, is BP or Caltex any better?
Edited by Dush73
  • 3 weeks later...
  • Member For: 16y 5m 15d
  On 15/07/2009 at 6:32 AM, seventytwo said:
I believe that 280rwkw is fairly easy to achieve tune only in an FG.
Thanks for the response 72 ....pretty much what I have discovered but they also seem to want to upgrade the air intake (CAI ?). Just what I suspected...these babies wanna breathe (who doesn't?). Might just do a CAI and a tune and see how that feels although after 2 years I am still pretty happy with the standard rig .....
  • Member For: 14y 6m 15d
firstly iv read this entire thread nd have already learnt alot I hav a 03 ba xr6t ute 5 speed manual it has the snorkle in the air intake already
(I think neway short rubber intake roughly 200mm long into rectangle hole in the front of box)is that right ? also I was told by a exaust shop that u wouldent get much sound/ performance difrence unless changing the entire system quoted $1600 , now I would like to get to around the 300rwkw mark what do u recomend also do they do coilover kits to replace the rear leaf springs in the ute's
chears
rohan
  • 1 month later...
  • Member For: 14y 3m 7d
I have just gone and brought a 05 bf f6 and joind this site and I must say a big thanks to everyone the advice I have recived so far has probly saved me a lot of head ache and money because ihad no idea were to start so thanks
  • 1 month later...
