Exhaust Manifold
  • Replies 22
Posted Images
  • Member For: 15y 8m 27d
He he nice photos of the datto with the turbs above bonnet height...
In reponse to Senna T I origianlly had the crossover pipe from Process west ( all polished priping and crossover pipe for sale too if anyones interested)
and it rubbed on the bonnet insulation. add heat copious amounts of heat>>> and it will possibly burn the paint on the bonnet.??
HArmonic balance from Who >?? Atomic ?
Anyway any more ideas on the tuner.?? What is BTA/Autotech like ?
Edited by Mr Typhoon 500kw
  • Member For: 16y 11m 16d
yes atomic 4 the balancer. even with your turb 2 or 3cm lower, it will still burn through the bonnet insulation. just get a beanie, is the to4 water cooled ? and all the above tuners are worthy.
yeah its a big turbo the front housing is a larger 4 inch along with the intercooler inlet being 3 inch not like the standard which I think is 2.5 inch... its actually an 850hp wheel. I made 400rwkw with the standard GT3540 but it was ringing its neck , I had the option to go for the GT4088 which is a 1000hp flywheel turbo but it would have come on boost at 3800 rpm or so (im told)and yes the motor does have billet oil pump gears, ARP main and head studs, new valve stem seals, angle cut valves including re-seating and all the port inlet and exhaust have been shaved. So from my investigation the head should add some to the flow.
