MJSXR6T Member 13 Member For: 17y 1m 28d Gender: Male Location: Brisbane Posted 30/03/09 01:14 PM Share Posted 30/03/09 01:14 PM I looked everywhere and could not find the answer so I have had to post the question.Does anyone know the difference if any between the BF MKII and the FG FPV shortmotors? Also will the FG FPV short, bolt into a BA MKII with all standard BA parts I.emanifolds, cross pipes, engine mounts etc? What kw should the FG FPV motor handle?Thanks in advance for your replies. Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/ Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 11m 29d Gender: Male Location: Earth Posted 30/03/09 01:22 PM Share Posted 30/03/09 01:22 PM The FG block has different engine mounts so won't be a straight swap. Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/#findComment-852181 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 10d Gender: Male Location: SW Sydney Posted 30/03/09 09:49 PM Share Posted 30/03/09 09:49 PM The FG F6 motor also has lower compression pistons, but aside from that its the same as far as we know for now.How much power are you chasing? The motors should be safe into the mid to high 300's, however its all up to the parts and tuning. The strongest motor can be destroyed by bad tuning... Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/#findComment-852233 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 1m 14d Gender: Male Posted 31/03/09 06:51 AM Share Posted 31/03/09 06:51 AM Yeah mate it will fit straight in all you need to do is grind a tiny bit off your engine mount as it hit a section of the new block:spoton:My buddy F6_charlie is running that setup.But if I was you idd drop a 08 phoon motor in, I just did that option its a bit cheaper and its the same comp ratio as the ba. Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/#findComment-852450 Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 22y 1m 22d Location: Geelong Victoria Posted 31/03/09 08:04 AM Share Posted 31/03/09 08:04 AM The BF MkIII wagon and FG both use the same block, and some late BF MkII sedans use the FG block too as the changeover happened a few months before the FG went into production. The FG style block has 2 dipstick holes in it, one at the front for BF, one at the back for FG, and one hole is plugged with something called an avseal. Plugging the rear whole should be all you need to do.Are you using the BA head? That might need to be investigated as the FG head is a little different, cams, staggered ports etc. Piston to valve clearance? Should be ok but might need to check. Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/#findComment-852512 Share on other sites More sharing options...
MJSXR6T Member 13 Member For: 17y 1m 28d Gender: Male Location: Brisbane Posted 31/03/09 10:04 AM Author Share Posted 31/03/09 10:04 AM YPURV4 said: Yeah mate it will fit straight in all you need to do is grind a tiny bit off your engine mount as it hit a section of the new block:spoton:My buddy F6_charlie is running that setup.But if I was you idd drop a 08 phoon motor in, I just did that option its a bit cheaper and its the same comp ratio as the ba.Thanks for the info. The BF and FG short is going to cost $2400 from Ford. Can you give me an idea of the price on the phoon motorplease. I was going to use this while building up the original with the good gear. To make this swap worthwhile, I am trying to achieve between 350 to 480 rwkw until the other block is finished. Thanks all for the information.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/#findComment-852659 Share on other sites More sharing options...
dat_40l Donating Members 997 Member For: 19y 11m 28d Gender: Male Location: newcastle NSW Posted 31/03/09 12:56 PM Share Posted 31/03/09 12:56 PM hye mate,I got the fg f6 bottom end in my ba mkI. justin at blacktrack performance in newcastle did it all. mine is pushing 392rwkw and its f*cking great!! maybe ring them if you want to know moremitch Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/#findComment-852787 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 1m 14d Gender: Male Posted 01/04/09 04:46 AM Share Posted 01/04/09 04:46 AM MJSXR6T said: Thanks for the info. The BF and FG short is going to cost $2400 from Ford. Can you give me an idea of the price on the phoon motorplease. I was going to use this while building up the original with the good gear. To make this swap worthwhile, I am trying to achieve between 350 to 480 rwkw until the other block is finished. Thanks all for the information.CheersThat price will be for the phoon motor mate after 06/06 all bf bottom ends are the same specs, and you couldnt find a block older than that sitting around at ford, im pretty sure they only ever keep like 8-10 short blocks at head spare parts office at a time?So yeah you will be getting a late 07 at the latest Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/#findComment-852998 Share on other sites More sharing options...
dat_40l Donating Members 997 Member For: 19y 11m 28d Gender: Male Location: newcastle NSW Posted 01/04/09 05:09 AM Share Posted 01/04/09 05:09 AM if you do get a fg motor to will have to modify the mounts but nothing major. pretty sure the rest bolts up Link to comment https://www.fordxr6turbo.com/forum/topic/56215-ba-mkii-short-to-a-fg-fpv-short/#findComment-853007 Share on other sites More sharing options...
