Snaps Member 79 Member For: 16y 8m 23d Gender: Male Location: Brisbane Posted 26/03/09 07:40 AM Share Posted 26/03/09 07:40 AM howdy, just had my car in at sunshine ford for a 60k service. They did all the normal crap that costs a poo load, and I ended up getting the power steering flushed and fuel system/ injectors cleaned aswell. (runs alot better now)but anyway, I got the car back and took it for a drive and noticed that now the car shifts higher in the rev range under full throttle. The car consistantly revs to 5900 through changes, I though it was a bit high? what do you guys think? was there a new PCM update? or is it a problem?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/56082-car-serviced-now-zf-shifts-higher/ Share on other sites More sharing options...
Plugg3r Caring Understanding Northern Territorian Member 159 Member For: 16y 11m 22d Gender: Male Location: Darwin, NT Posted 27/03/09 12:03 AM Share Posted 27/03/09 12:03 AM At full throttle it revs to 5900? Mine does that in 1st but not second it goes 6000-6100.. Link to comment https://www.fordxr6turbo.com/forum/topic/56082-car-serviced-now-zf-shifts-higher/#findComment-849773 Share on other sites More sharing options...
wiresquire Member 266 Member For: 20y 7m Posted 27/03/09 12:12 AM Share Posted 27/03/09 12:12 AM The ZF/ECU combo will shift at different rpms, depending on a variety of factors.Check out the owner's manual, it has some interesting info on this.Also check out this link for the section about Transient RPM limit. See if you can get it to go to 6250 ;-)ws Link to comment https://www.fordxr6turbo.com/forum/topic/56082-car-serviced-now-zf-shifts-higher/#findComment-849783 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 7m 17d Location: In The Ute Posted 27/03/09 12:25 AM Share Posted 27/03/09 12:25 AM Just means that the transmission has learnt to shift differently since it was sent in for its service as it learns to adapt to the way its been driven.So In short Your Ford dealer apprentices have possibly thrashed the sh*t out of it whilst they had it!!! hence the shift points being different now.Take a look at your fuel consumption and I bet it shot up also since the service. Happens all the time but you will have a hard time proving it unless you write down the speedo reading when you dropped it off including Fuel consumption data etc so as the back up your thoughts. Link to comment https://www.fordxr6turbo.com/forum/topic/56082-car-serviced-now-zf-shifts-higher/#findComment-849804 Share on other sites More sharing options...
Plugg3r Caring Understanding Northern Territorian Member 159 Member For: 16y 11m 22d Gender: Male Location: Darwin, NT Posted 27/03/09 01:26 AM Share Posted 27/03/09 01:26 AM wiresquire said: The ZF/ECU combo will shift at different rpms, depending on a variety of factors.Check out the owner's manual, it has some interesting info on this.Also check out this link for the section about Transient RPM limit. See if you can get it to go to 6250 ;-)wsSo basically that saying if we leave in Manual mode and give it a flogging it's going to learn how to do that? Link to comment https://www.fordxr6turbo.com/forum/topic/56082-car-serviced-now-zf-shifts-higher/#findComment-849822 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 18d Gender: Male Location: SW Sydney Posted 27/03/09 01:31 AM Share Posted 27/03/09 01:31 AM that's exactly right Plugger Link to comment https://www.fordxr6turbo.com/forum/topic/56082-car-serviced-now-zf-shifts-higher/#findComment-849825 Share on other sites More sharing options...
Snaps Member 79 Member For: 16y 8m 23d Gender: Male Location: Brisbane Posted 01/04/09 12:38 PM Author Share Posted 01/04/09 12:38 PM F6_Tornado said: Just means that the transmission has learnt to shift differently since it was sent in for its service as it learns to adapt to the way its been driven.So In short Your Ford dealer apprentices have possibly thrashed the sh*t out of it whilst they had it!!! hence the shift points being different now.Take a look at your fuel consumption and I bet it shot up also since the service. Happens all the time but you will have a hard time proving it unless you write down the speedo reading when you dropped it off including Fuel consumption data etc so as the back up your thoughts. that sounds like the ticket. the fuel usage did go up a little. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/56082-car-serviced-now-zf-shifts-higher/#findComment-853412 Share on other sites More sharing options...
