Huffed347 Inactive Members 1 Member For: 16y 2m 9d Posted 23/03/09 05:19 PM Share Posted 23/03/09 05:19 PM First post so be gentle on me please.A little background on where I am coming from.I have just aquired an XG drag ute and want to run a Turbo 6 engine in it. Power will not be huge to start with as it will be run as an 11 sec combo at around 450 RWHP but engineered to step up a little down the track.I am also trying to get my head around the best starting place for a healthy Turbo 6 combo.I have read that the EGas engines (both BA and BF) had uprated Rods and Springs. Is this correct?Is the cylinder head as good a starting place as a T head?Alternatively, would it be a reasonable move to grab a Late 06 BF N/A engine and throw some rods, pistons and valve springs etc at it to bring it up to Turbo specs?As you can see, I am more interested in the core engines ability to hold up under the stress of Turboing. Are the above mods heading me in a Turbo spec direction?I would want to run BF electronics etc and am unsure about VCT issues on both the EGas and BF N/A engines.All the outboard stuff like manifolds and Turbo are not an issue for my project. They can be soughted and sourced when I have a total plan.From what I can see there are plenty of way tougher engines within this forum so the help will be greatly appreciated.Thought it would be smart to go to the source for these questions.Really interested in your input. Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/ Share on other sites More sharing options...
Benny-4000 Member 31 Member For: 17y 3m 18d Posted 28/07/09 12:17 PM Share Posted 28/07/09 12:17 PM (edited) I believe the Egas engine also has the inconel valve seats like the turbo engine Edited 28/07/09 12:29 PM by seventytwo Quote removed Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/#findComment-913505 Share on other sites More sharing options...
Azzman460 Azzman Member 223 Member For: 16y 10m 10d Gender: Male Location: Melbourne Posted 30/07/09 04:47 AM Share Posted 30/07/09 04:47 AM Hey guys, on this note, would a standard N/A Head be ok to put onto a built turbo bottom end? Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/#findComment-914306 Share on other sites More sharing options...
lukedohc Donating Members 141 Member For: 16y 7m 20d Posted 30/07/09 06:44 AM Share Posted 30/07/09 06:44 AM the compression is to high on the e-gas for turboing Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/#findComment-914338 Share on other sites More sharing options...
Benji_vs Donating Members 403 Member For: 17y 26d Gender: Male Location: East Suburbs Melbourne Posted 31/07/09 07:48 AM Share Posted 31/07/09 07:48 AM its around the 10.7:1 region I think, so yeah too high for any serious boost Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/#findComment-914800 Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 22y 1m 7d Location: Geelong Victoria Posted 31/07/09 11:56 AM Share Posted 31/07/09 11:56 AM Pistons are different, valve springs are different and the exhaust valves are not inconel like the turbo versions.They share the same rods and hardened valve seats though. Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/#findComment-914949 Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 6m 8d Gender: Male Location: Perth Posted 31/07/09 12:10 PM Share Posted 31/07/09 12:10 PM dont worry about the cams for a drag car.engine of the day, they are going to be fixed in position ideal for drag racing. not economy.so just grab an aftermarket ecu, will give you better parameters etc.the high compression = higher power on same boost.just use dry ice cooling to keep those temperatures down to avoid detonation Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/#findComment-914955 Share on other sites More sharing options...
Benji_vs Donating Members 403 Member For: 17y 26d Gender: Male Location: East Suburbs Melbourne Posted 02/08/09 08:48 AM Share Posted 02/08/09 08:48 AM Tocchi said: the high compression = higher power on same boost.just use dry ice cooling to keep those temperatures down to avoid detonation Very true but you would want to use very high octane fuel or you would run the risk of detonation Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/#findComment-915684 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 7d Gender: Male Location: Far north queensland Posted 04/08/10 07:49 PM Share Posted 04/08/10 07:49 PM what about on standard boost levels of 6-8psi? Link to comment https://www.fordxr6turbo.com/forum/topic/55993-ba-bf-egas-engine-for-turbo-conversion/#findComment-1030092 Share on other sites More sharing options...
