  • Member For: 16y 1m 3d
Any turbo shop should be able to get you a .70 A/R comp cover.
You’re going to need to make a new or modify the factory wastegate bracket to fit the .70 A/R cover.
The .70 A/R scroll is too big for the factory bracket to fit around and the bolts are spaced differently to the .50 A/R cover.
  • Replies 23
  • Cryptic Clothing Company
  • Member For: 16y 9m 15d
I just did mine over the weekend
it very easy to take off
I'll give u a quick run down, its heaps easier on a set of car ramps
1. drain coolant.
2. take of the piping
3. take heat sheilds off
4. undo the hotside piping
5. undo the oil and water lines. a lil bit of oil will fall out as with water
6. undo the bolts that hold on the dump pipe
7. undo the 4 bolts that hold on the turbo to the manifold.
8. shuld pull right out.
9. once its out u shuld be able to undo all the bolts around the front housing and shuld pull off
to put on the 0.7 housing u will need a different ring that goes on the inside of the housing
and same process to put back.. it sounds a lot more difficult than it is
  • BOOST
  • Moderating Team
  • Member For: 21y 7m 20d
by changing the front will it actually make much of a difference?? The inner holes look pretty much the same size
yeh it is.. cuz I never changed the wheel. but the outlet is 2.5in
  • Member For: 17y 3m 27d
got a pic of it fitted dude? can I ask how much it was? I was gunna polish mine n put it on a high mount, but one of these will make life alot easier n look better
I paid $500 for the front housing, the acuator bracket, the 38mm flapper and the ring
btw.. it was a b*tch getting the silicone on there..
Edited by typhoon_freak
There is a bolt on .70 A/R comp cover kit for $550
It comes with a .70 A/R cover that has the same bolt spacing as the factory comp cover. It does not require the ring.
It also has a stainless wastegate bracket that looks similar to the factory bracket but fits around bigger comp cover.
You can also get it with the 4" inlet or the standard inlet.
I got mine from mr turbo on the gold coast
