  • Member For: 16y 9m 24d
  • Gender: Not Telling
When I got booted for running the 11.1, the guy actually said cars with a two piece tailshaft don't require a TS loop as the bracket supporting the centre bearing area acts as your loop. Unusually smart thing for a motorplex staff member to say really, since only one loop on a two piece shaft is useless.
P.S: below excuse for the 11.1, found the next time I drove the car.
  • Member For: 17y 4m 28d
I'll be there this coming Wednesday! Hopefully I get kicked!! I'm a noob at launching though so it might not happen :)
All tips appreciated. I'll be running on my Kumho KU31's at stock pressures most likely and with the spare in the boot still :)
Yeah I normally run 36psi rear/38psi front which is high for the drags. You reckon low 20s maybe? I don't have a pressure tester pen so I'd wanna do it at a servo on the way there I guess. Kinda keen to run it as it is on the street though so not sure yet :)
That sounds good, thanks. Yeah hopefully I get used to the "loss of traction point" rapidly so that I don't waste too many runs getting mid to high 12's!
You can be a passenger in cars that run 12's or slower too! :buttrock::beerchug::roflmbo::turboboink:
Is it going to be worth building much boost on the line with KU31's under me? Or will it just result in wheelspin?
  • <put funny sh*t here>
  • Member For: 18y 5m 13d
Do a real good burnout and get them hot and try your luck. Just build up the boost a bit more on each launch and learn how far you can push it before it breaks into excess wheel spin :)
