  • Just a large member member
  • Member For: 16y 6m 14d
  Trough Lolly said:
basically youd need to drop the sump to see if their BS'ing you mate.... or a compression test could help if the aftermarket parts change compression ratio from the original factory compressions.
no compression test wont tell you need to cc the head for that. If cam has been changed longer overlap might mean less compression
