  • Member For: 16y 3m 28d
is there anyway to know if someone has actually repalaced any engine internals ie conrods or valve springs?
obviously a reciept is good but if u have to take someones word for it is there anyway to know if they telling the truth?
https://www.fordxr6turbo.com/forum/topic/55829-engine-internals-replaced/
  • Member For: 17y 1m 15d
I was sceptical about where or not a workshop did my valve springs until I gave it a good hit of WOT and had no valve float.
Why dont you ask for the old parts that they replaced. The workshops I go to usually leave it on the passenger seat for me when I pick up the car
  • Member For: 20y 7m 10d
basically youd need to drop the sump to see if their BS'ing you mate.... or a compression test could help if the aftermarket parts change compression ratio from the original factory compressions.
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 21d
:censored:
Go back to the shop where the parts were supposably installed & get info from them.
