Falcon Fan Member 9 Member For: 15y 10m 19d Posted 21/05/09 11:47 AM Share Posted 21/05/09 11:47 AM just wondering how do you reset/recalibrate the TPS then?cheers Link to comment Share on other sites More sharing options...
baboon Member 141 Member For: 21y 4m 24d Gender: Male Location: Geelong, VIC, Australia Posted 23/05/09 02:11 PM Share Posted 23/05/09 02:11 PM just wondering how do you reset/recalibrate the TPS then?cheersThe TPS is really a mechanical device. It doesnt have any brains and is actually a dumb device. Its a bit like a volume control knob on your radio. You turn it clockwise the volume goes up, anti-clockwise the volume goes down. You cant really reset/recalibrate the volume knob. You can however recalibrate the amplifier its controlling. In the case of the TPS, the PCM reads the position of the TPS and responds accordingly. The error is only created inside the PCM.The only way to reset the error is to take battery off for 30mins and replace. A faulty TPS will send the PCM the wrong values. Replacing the TPS is the only way to fix that problem. Also, there could be a slight chance the PCM is at fault too. Link to comment Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 6m 14d Gender: Male Location: Melbourne Posted 02/06/12 03:18 AM Share Posted 02/06/12 03:18 AM Is this true then - foot flat to the floor does nothIng to recalibrate TPS Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 2m 28d Gender: Male Location: SE Melbourne Posted 02/06/12 06:39 AM Share Posted 02/06/12 06:39 AM Gaz, flat to the floor while cranking is supposed to reset VCT and other PCM changes. Not the actual TPS itself. 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 27d Gender: Male Location: Perth Posted 02/06/12 06:42 AM Share Posted 02/06/12 06:42 AM The PCM cycles the Throttle open and closed when first powered up. This is the self check sequence for the TPS 1 Link to comment Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 6m 14d Gender: Male Location: Melbourne Posted 02/06/12 06:51 AM Share Posted 02/06/12 06:51 AM Ahhh - thanks mateys Link to comment Share on other sites More sharing options...
XR6menace BANNED Banned 1,462 Member For: 17y 9m 22d Gender: Not Telling Location: banned Posted 02/06/12 08:47 AM Share Posted 02/06/12 08:47 AM Also Gents...The cam phasers.The VCT has solenoids under the cam covers, these are known to stick when they become gummy with poor oil.Some people remove them and unstick them with some contact cleaner.Most times they do not need to be removed to reset the cams, its a simple procedure.Get in the car and put the key in the ignition.Put your foot flat to the floor on the accelerator pedal.Turn key and start cranking the engine for 10 seconds straight (the car will not/should not start).Turn ignition off and remove key.This seems to remedy a few issues eh... Link to comment Share on other sites More sharing options...
