bjc Donating Members 2,823 Member For: 21y 8m 21d Gender: Male Location: Townsville Posted 21/09/10 05:34 PM Share Posted 21/09/10 05:34 PM What power are you chasing? The wastegate and actuator mod is generally to control boost better. I was running 330rwkw without dramas on my standard turbo with the split dump and 3.5in system, also had rapids intercooler kit with the 4in intake. It did take the tuner a little longer to get it more stable though.I am now getting the housing flowed and ported slightly as I'm keeping the standard flapper on and will prob use an actuator off the FG turbos. Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1042123 Share on other sites More sharing options...
matt47569 Member 39 Member For: 15y 6m 11d Posted 21/09/10 10:03 PM Share Posted 21/09/10 10:03 PM only after low-mid 200's due to my car being N/A and having a turbo conversion done. would be running low boost 7-8 psi and want to make the most out of it. using an aftermarket boost controller Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1042138 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 21d Gender: Male Location: Townsville Posted 22/09/10 09:52 AM Share Posted 22/09/10 09:52 AM (edited) I would not bother modding the turbo with the low boost you will be running, there should be no problems controlling boost at all. Edited 22/09/10 09:53 AM by bjc Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1042313 Share on other sites More sharing options...
matt47569 Member 39 Member For: 15y 6m 11d Posted 23/09/10 07:43 AM Share Posted 23/09/10 07:43 AM (edited) ok cool. I mostly want the aftermarket dump so it will reach where my aftermatket cat and exhaust starts so I dont have to hack up the stock xr6t exhaust so the factory dump reaches to where I need.. should spool a bit quicker too with the 3.5" split Edited 23/09/10 07:45 AM by matt47569 Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1042502 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m Gender: Male Location: Far north queensland Posted 27/09/10 07:03 AM Share Posted 27/09/10 07:03 AM :( Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1043353 Share on other sites More sharing options...
Redback Banned 236 Member For: 15y 11m 14d Gender: Male Location: Blacktown NSW Posted 03/10/10 02:16 PM Share Posted 03/10/10 02:16 PM What is the max power u can squeeze out of the 4" dump into 3.5" straight system before creating too much back pressure? Can you c it over 400rwkw? Also has any one had any experiences with the Tunehouse sytem? Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1044925 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 9m 7d Gender: Male Location: Broady, Melbourne Posted 03/10/10 03:44 PM Share Posted 03/10/10 03:44 PM (edited) That sized exhaust set-up will flow over 400rwkw. As to back pressure, that can be tweaked by a different cat. An e85 set-up would be nice as well as far as making over 400rwkw.XForce cats have had problems and fitment is an issue, as with any off-the-shelf exhaust. My XForce split dump and 3.5inch set-up needed some tweaking to get it right. A crow bar, drill and grinder was needed to get it to fit nicely. But it worked nice. No bangs and good consistent power, until the cat collapsed recently. It ended up sitting in the rear muffler where it managed to cause a little extra back pressure I heard it get blown from it's casing and lodge in the rear muffler one night whilst giving it a little throttle. I haven't seen a Tunehouse exhaust in the flesh but the word on the street (sesame) is dey is da shizzle. Cookie monster told me so.That's where something like the Tunehouse setup would be better I'd say. Fitment, flow and quality. Edited 03/10/10 03:47 PM by straughsberry Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1044931 Share on other sites More sharing options...
Redback Banned 236 Member For: 15y 11m 14d Gender: Male Location: Blacktown NSW Posted 03/10/10 10:24 PM Share Posted 03/10/10 10:24 PM Thanks for that sraughberry. I was lucky and didn't have any fitttment issues with it and the cat has held out so far. I just don't want to put the new engine in and have it on the dyno to find out the exhaust cannot flow anymore now past say 400rwkw. Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1044947 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 21d Gender: Male Location: Townsville Posted 03/10/10 10:36 PM Share Posted 03/10/10 10:36 PM If you have the twin tip for this exhaust it is restricitve, I gained 2psi straight up changing to a single straight through muffler. This advice was given to me by Dave (blueboost) and proved right.Search my posts and you'll find pics of it internally at the back the twin tips taper into small diameters! Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1044949 Share on other sites More sharing options...
Redback Banned 236 Member For: 15y 11m 14d Gender: Male Location: Blacktown NSW Posted 03/10/10 11:38 PM Share Posted 03/10/10 11:38 PM Hey BJC. I had heard that this was a restricition on this system. What muffler did you end up using? Obviously it is a custom job. Any idea on the brand of muffler u used? Is it stainless? What kind of KW are u now supporting with that system? Link to comment https://www.fordxr6turbo.com/forum/topic/55751-xforce-exhaust-thread/page/57/#findComment-1044964 Share on other sites More sharing options...
