Ace blind leading the blind Member 3,657 Member For: 16y 8m 11d Gender: Male Location: Mt Alford, Queensland Posted 16/03/09 11:33 AM Share Posted 16/03/09 11:33 AM bentles said: yeah mine makes the same noise I think. once warm if I and at lights in neutral and take foot off clutch it makes the sound discribed. as soon as I put clutch in it quiet as.this cant be fixed?go the option 3 sunny. ordered mine today.cheers dylan.that's sounds like the old school throw out bearing noise - but that couldnt be right could it Link to comment https://www.fordxr6turbo.com/forum/topic/55724-bf-mk2-t56-noises/page/2/#findComment-843301 Share on other sites More sharing options...
Coley Member 110 Member For: 17y 20d Gender: Male Location: Ipswich Posted 16/03/09 11:44 AM Share Posted 16/03/09 11:44 AM Sundeep said: Cheers for your help Senna. Much appreciated. I'm looking in to some mods currently and have found that I will prob need a clutch straight away. Looking in to Mal Wood Option 3 with 11" flywheel.I've got 310rwkw and am still using the stock clutch and have been for a while. Just dont launch hard off the line and you will be fine Link to comment https://www.fordxr6turbo.com/forum/topic/55724-bf-mk2-t56-noises/page/2/#findComment-843312 Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 16y 2m 25d Gender: Male Posted 19/03/09 06:19 AM Share Posted 19/03/09 06:19 AM ^Really? I've only got 250rwkw and I find it slips in high gears if there is an incline and WOT. partly due to the 13 psi at 3000rpm and the slab of torque it has to deal with before trailing back to 10 psi....Solution? change to a lower gear, and avoid peak boost.... that is until I can convince the minister for finance that an option 3 clutch is needed... Link to comment https://www.fordxr6turbo.com/forum/topic/55724-bf-mk2-t56-noises/page/2/#findComment-845104 Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 16y 2m 25d Gender: Male Posted 19/03/09 06:23 AM Share Posted 19/03/09 06:23 AM As for the gearbox noise... I was driving at night with my wife, radio off, no air-con, just peace and quiet... and she says "whats that...noise... it sounds like a kettle boiling...." Took me a little while to figure out what she was hearing... Link to comment https://www.fordxr6turbo.com/forum/topic/55724-bf-mk2-t56-noises/page/2/#findComment-845108 Share on other sites More sharing options...
RapidF6 Member 125 Member For: 16y 8m 17d Gender: Male Location: Fremantle, W.A. Posted 19/03/09 06:37 AM Share Posted 19/03/09 06:37 AM There's another oil which may be worth a try. It is made specifically for the T56 gearbox and is called mainlube (synthetic solid boundary). Google that. Apparently it is expensive but lasts up to a claimed 100km. Link to comment https://www.fordxr6turbo.com/forum/topic/55724-bf-mk2-t56-noises/page/2/#findComment-845119 Share on other sites More sharing options...
bentles Member 121 Member For: 16y 7m 23d Gender: Male Location: melbourne Posted 23/03/09 07:17 AM Share Posted 23/03/09 07:17 AM ok all im doing my clutch this weekend, now I will doing a oil change on my t56 with transmax z, do you boys just fill till comes out the fill hole or do you's put in more or what? Link to comment https://www.fordxr6turbo.com/forum/topic/55724-bf-mk2-t56-noises/page/2/#findComment-847231 Share on other sites More sharing options...
Craig. Member 563 Member For: 18y 2m 2d Gender: Male Location: Sunshine Coast QLD Posted 23/03/09 07:29 AM Share Posted 23/03/09 07:29 AM (edited) In 6 cyl, Ford recommends 4.8 ltrs. That's 1ltr more than what they recommend to fill the same box takes on an V8. They over fill it on the 6 to try to quieten it down apparently as it is more prone to the roll over noise.To get 4.8 ltrs into her, you will have to remove the reverse signal switch and fill it from there, or jack up the passengers side so the car is on an angle and fill it from the normal place. Edited 23/03/09 07:31 AM by craiginmackay Link to comment https://www.fordxr6turbo.com/forum/topic/55724-bf-mk2-t56-noises/page/2/#findComment-847251 Share on other sites More sharing options...
