BLK6T Member 305 Member For: 20y 1m 6d Gender: Male Location: Sydney NSW Posted 15/03/09 06:36 AM Share Posted 15/03/09 06:36 AM Hi All,I was cleaning my throttle body yesterday and whilst re-connecting my PCV Pipe into the crossover manifold the screw thread snapped off the hose. Now I cannot connect the PCV Pipe to the manifold. If I drive the car with no PCV pipe, will it cause any damage? Also what is the function of a PCV pipe and roughly how much will a replacement cost from Ford?Thanks for the advice and help!Cheers Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 3m 2d Gender: Male Location: Perff, WA Posted 15/03/09 06:46 AM Share Posted 15/03/09 06:46 AM Questions answered here...I've got mine taped over until it comes on monday. recommend not leaving it open Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 6m 27d Gender: Male Location: Victoria Posted 15/03/09 08:47 AM Share Posted 15/03/09 08:47 AM The threaded fitting is cheap... The little bit of plastic hose is not.When I broke mine I just sealed it with silicone until I got the new parts. You'll just notice a tiny bit of oil spitting out of the dip stick tube. Link to comment Share on other sites More sharing options...
BLK6T Member 305 Member For: 20y 1m 6d Gender: Male Location: Sydney NSW Posted 15/03/09 09:01 AM Author Share Posted 15/03/09 09:01 AM great, thanks guys. I just taped it up then and will try to get the parts tomorrow. Bloody cheap flimsy part though. It snapped so easily. Oh well, lesson learned.Cheers Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 5m 2d Gender: Male Location: Earth Posted 15/03/09 12:45 PM Share Posted 15/03/09 12:45 PM Guys, that's not the PCV pipe fitting or whatever you want to call it.It's just a breather pipe and fitting.The PCV and it's associated piping is at the rear of the rocker cover and joins in somewhere at the rear of the inlet manifold.The function of the PCV is for emissions purposes.The breather pipe and fitting that you are referring to is just a breather. Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 3m 2d Gender: Male Location: Perff, WA Posted 15/03/09 01:04 PM Share Posted 15/03/09 01:04 PM (edited) Bloody cheap flimsy part though. It snapped so easily.yeah, I was surprised at how flimsy it was, but more annoyed that I'd snapped it! *insert facepalm pic*Guys, that's not the PCV pipe fitting or whatever you want to call it.It's just a breather pipe and fitting.The PCV and it's associated piping is at the rear of the rocker cover and joins in somewhere at the rear of the inlet manifold.The function of the PCV is for emissions purposes.The breather pipe and fitting that you are referring to is just a breather.Thanks for letting us know... again. Ford, who people will be describing the part to in order to purchase it, call it a PCVQuote; Reef City Ford"BA9V684A is a valve @ $17. The hose would be BA6C661A @ $31" I know it's not actually a valve, but it is called valve, that's all Edited 15/03/09 01:06 PM by Superdan Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 5m 2d Gender: Male Location: Earth Posted 15/03/09 01:17 PM Share Posted 15/03/09 01:17 PM No worries Superdan, but some people aren't aware that it isn't actually a PCV.As a mechanic, if my breather pipe or fitting broke and I rang Ford for a replacement part, I'd be asking for exactly what it is, not what a parts interpretter tries to tell me what it is. It also helps those that don't know what things are to name and describe things correctly so no one gets confused. Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 3m 2d Gender: Male Location: Perff, WA Posted 15/03/09 01:24 PM Share Posted 15/03/09 01:24 PM Simple part number worked for me, anyhoo, how about that weather!? Link to comment Share on other sites More sharing options...
BLK6T Member 305 Member For: 20y 1m 6d Gender: Male Location: Sydney NSW Posted 15/03/09 11:44 PM Author Share Posted 15/03/09 11:44 PM Ahh, thanks Phantmxr6...so its a breather. It should be easier now to explain to Ford. What is its purpose? Link to comment Share on other sites More sharing options...
BLK6T Member 305 Member For: 20y 1m 6d Gender: Male Location: Sydney NSW Posted 18/03/09 09:30 AM Author Share Posted 18/03/09 09:30 AM Well after the ringing around I picked up the part today which is completely different to the one I broke. It is the correct part but it appears to have been upgraded somewhere along the line. Its a lot better and stronger and the pipe slides straight in and locks into place, easy. The guy from Ford had no idea what its called either, he called it a valve for "something"...mmmmm. But fix one thing and another breaks...my RH fog light got cracked today, luckily I have a replacement on hand. Very annoying though... Link to comment Share on other sites More sharing options...
