Ute Boy Member 10 Member For: 16y 8m Posted 14/03/09 05:16 AM Share Posted 14/03/09 05:16 AM Hi guys, I lowered my ute today with super lows all round. For the back I used FOR-801 and for some reason the left is sitting lower than the right (if you are looking at it from the rear). They both had diff numbers on them, the right had 800/100 and the left had 800/85. I rang king springs and they said that the springs are diff strengths to compensate for fuel and other components so this was ok. I also haven't cut the bump stops yet and the one on the left is about 10mm away from the bump stop and 25 on the right. Also the left leaf has been stretched past horizontal and is sort of bending the opposite way a leaf should sit. What have you guys experienced? Comments would be greatly appreciated. Link to comment Share on other sites More sharing options...
mercuryturbo Oh look.... a real car, with no hair dryer Donating Members 1,724 Member For: 18y 3m 3d Gender: Male Location: Fear and Loathing in Callala Bay Posted 14/03/09 06:43 AM Share Posted 14/03/09 06:43 AM Probably a dumb question but are the springs on the right side? Link to comment Share on other sites More sharing options...
Ute Boy Member 10 Member For: 16y 8m Posted 14/03/09 07:38 AM Author Share Posted 14/03/09 07:38 AM Good question, but yes they are on the right side. Link to comment Share on other sites More sharing options...
Ute Boy Member 10 Member For: 16y 8m Posted 15/03/09 03:59 AM Author Share Posted 15/03/09 03:59 AM (edited) Hi I have recently lowered my 2003 xr6 ute with sl all round (FOR-801 rear KFFL-57SL front) and the rear is sitting very low. at the back it is sitting 315mm and I was told it would sit around 340mm-345mm (measured from centre of hub). What have u guys experienced when lowering your utes? Edited 15/03/09 07:22 AM by Dagabond Link to comment Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 18y 7m 1d Gender: Male Location: Bentleigh, Vic, Australia Posted 15/03/09 04:52 AM Share Posted 15/03/09 04:52 AM The rear looks about right.But the fronts I'm not too sure about.I have the same spring setup as you said KFFL-57SL and FOR801 rears and this is how it looks with 19'sCheck and make sure the fronts are actually KFFL-57SL's and not KFFL-57. Link to comment Share on other sites More sharing options...
Ute Boy Member 10 Member For: 16y 8m Posted 15/03/09 05:14 AM Author Share Posted 15/03/09 05:14 AM The rear leafs are like bending the opposite way to a normal leaf should ( opposite to U shape) is this the same as yours? Link to comment Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 18y 7m 1d Gender: Male Location: Bentleigh, Vic, Australia Posted 15/03/09 05:18 AM Share Posted 15/03/09 05:18 AM so your leafs are bending beyond being flat... they actually flex the opposite way? If they do, someone has f*cked something up royally!Take it to another suspension place, goto Pedders or somewhere that specialises in suspension components. I've found places that just do lowering seem a bit clueless beyond alignments and springs. Link to comment Share on other sites More sharing options...
Ute Boy Member 10 Member For: 16y 8m Posted 15/03/09 05:27 AM Author Share Posted 15/03/09 05:27 AM Yeah beyond flat, I installed myself but I am sure I installed it right. Cant exactly go wrong. did you have different numbers on your drivers side and passengers side springs? on the drivers side I had 800/100 and on the passengers side I had 800/85. King springs said that this is the right way round but I am not so sure. I am posotive king springs f***ed up somwhere. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 9m 6d Gender: Male Location: SW Sydney Posted 15/03/09 05:30 AM Share Posted 15/03/09 05:30 AM Mate, take it straight to a suspension specialist. Check the Kings web-site for part numbers and see if there is a difference between Left and Right hand spring (I can't see there being a different height though)Suspension and brakes are something you should never stuff around with unless you are 100% sure of what you are doing - a small mistake could end up in disaster in these areas. Link to comment Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 18y 7m 1d Gender: Male Location: Bentleigh, Vic, Australia Posted 15/03/09 05:32 AM Share Posted 15/03/09 05:32 AM Its possible kings may have sent you the wrong rear springs. Going by the fronts I doubt they are KFFL-57SL's. Look more like KFFL-57'sAs for the numbers on the rear leafs im not too sure mate, can't help you out there sorry. Link to comment Share on other sites More sharing options...
