xr6tute Member 50 Member For: 18y 4m 23d Gender: Male Posted 15/03/09 12:36 AM Share Posted 15/03/09 12:36 AM I haven't used my heater since last summer.....but with this awesome weather we have had in Melbourne recently ( its shocking I am over winter and it hasn't even started ) I switched the heater on and all I got was cold air.Its as if the temp. selector is jammed on cold...has anyone had this happen in one of these cars before and if so what was the problem.Thank you Link to comment https://www.fordxr6turbo.com/forum/topic/55693-heater-problem-help/ Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 17y 7m 27d Gender: Male Location: Adelaide Posted 15/03/09 12:59 AM Share Posted 15/03/09 12:59 AM there seems to be alot of this going on at the moment :(Broken Air mix shaft in heater box1.) remove dash2.) disassemble front of heater box3.) replace shaft4.) reassembletry serching for some info on it dude but that's gonna be your probmike Link to comment https://www.fordxr6turbo.com/forum/topic/55693-heater-problem-help/#findComment-842156 Share on other sites More sharing options...
mercuryturbo Oh look.... a real car, with no hair dryer Donating Members 1,724 Member For: 18y 8m 22d Gender: Male Location: Fear and Loathing in Callala Bay Posted 15/03/09 01:05 AM Share Posted 15/03/09 01:05 AM My heater doesnt work either & that's the problem. Link to comment https://www.fordxr6turbo.com/forum/topic/55693-heater-problem-help/#findComment-842159 Share on other sites More sharing options...
xr6tute Member 50 Member For: 18y 4m 23d Gender: Male Posted 15/03/09 10:56 AM Author Share Posted 15/03/09 10:56 AM Mike XR6T said: there seems to be alot of this going on at the moment :(Broken Air mix shaft in heater box1.) remove dash2.) disassemble front of heater box3.) replace shaft4.) reassembletry serching for some info on it dude but that's gonna be your probmikethanks for your help mate...I was hoping it would be something that didnt require the removal of the dash. When you say remove dash, exactly which part of the dash needs to come out ? will it be the whole lot or just a section off it?thanks Link to comment https://www.fordxr6turbo.com/forum/topic/55693-heater-problem-help/#findComment-842562 Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 17y 7m 27d Gender: Male Location: Adelaide Posted 15/03/09 11:14 AM Share Posted 15/03/09 11:14 AM :( the whole lot buddysorry for the bad news Link to comment https://www.fordxr6turbo.com/forum/topic/55693-heater-problem-help/#findComment-842584 Share on other sites More sharing options...
tmac450 Member 1,650 Member For: 18y 7m 28d Gender: Male Location: NSW Posted 15/03/09 09:23 PM Share Posted 15/03/09 09:23 PM Mine did it. I took it to the dealer who said they "Reset the heater module", whatever that is?Good news is that the heater worked, but they fried the head unit in the porcess, which meant a whole new ICC, which took them 6 months to get in and replace.Good luck! Link to comment https://www.fordxr6turbo.com/forum/topic/55693-heater-problem-help/#findComment-842747 Share on other sites More sharing options...
