  • Member For: 18y 4m 25d
I haven't used my heater since last summer.....but with this awesome weather we have had in Melbourne recently ( its shocking I am over winter and it hasn't even started ) I switched the heater on and all I got was cold air.
Its as if the temp. selector is jammed on cold...
has anyone had this happen in one of these cars before and if so what was the problem.
Thank you
https://www.fordxr6turbo.com/forum/topic/55693-heater-problem-help/
  • iTs alL DaRDy........
  • Member For: 17y 7m 29d
there seems to be alot of this going on at the moment :(
Broken Air mix shaft in heater box
1.) remove dash
2.) disassemble front of heater box
3.) replace shaft
4.) reassemble
try serching for some info on it dude but that's gonna be your prob
mike
  • Oh look.... a real car, with no hair dryer
  • Member For: 18y 8m 24d
:stupid:
My heater doesnt work either & that's the problem.
1.) remove dash
3.) replace shaft
4.) reassemble
mike
thanks for your help mate...I was hoping it would be something that didnt require the removal of the dash. When you say remove dash, exactly which part of the dash needs to come out ? will it be the whole lot or just a section off it?
thanks
Mine did it. I took it to the dealer who said they "Reset the heater module", whatever that is?
Good news is that the heater worked, but they fried the head unit in the porcess, which meant a whole new ICC, which took them 6 months to get in and replace.
Good luck!
