  • Member For: 16y 7m 27d
Hey all,
Just had my baxr6t.ute in to ford for an extended warranty service - all waz ok, had a dodgy front right ball joint so they replaced it under warranty. Told them about the clunking noise in the rear and they said it was a loose spring leaf (?????) and that they had tightened it for me. But the clunking noise was still there when I left.
All in all I was pretty happy with Fords service.
They did however tell me I need my front pads replaced urgently (withing 2000 kms) - looking into that. And that my radiator fluid needs changing urgently also.
My question is :dontknow: why would radiator fluid need to be changed 'urgently' and is it something I can do myself? (being fairly mechanically minded).
Cheers guys :beerchug:
https://www.fordxr6turbo.com/forum/topic/55674-radiator-issues/
  • Me
  • Member For: 18y 2m 27d
These things have a nasty habit of failing radiators and trans fluid mixing with coolant. If its an auto I would change the coolant asap. Fraud now sell the correct coolant premixed.
  • Hey guys, Tab is here... Oh i feel sick
  • Member For: 17y 1m 1d
because the coolant has a lube in it and keeps the water pump and thermostat ect it good working condition, if it gets to old it starts to break down and doesnt work properly. gone are the days of just putting water from your hose in the radiator
Wow, didn't realize that it had lubricant in it. It is pretty discoloured.
Cheers for that fellas, I think I'll change it today.
:stupid:
