mic Donating Members 1,725 Member For: 17y 2m 27d Gender: Male Posted 12/03/09 08:35 AM Share Posted 12/03/09 08:35 AM IH8TOADS said: I'm sure he will cross reference but idle quality improved when an unsaid few worked on my car. Most noticable improvement was the lack of 'hunting' on decel. Danny....much appreciated input.hunting, sweet as I have 2 try this. cheers headsex. Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840476 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 6d Gender: Male Location: OZ Posted 12/03/09 08:36 AM Share Posted 12/03/09 08:36 AM _Spin_ said: mate can you define " hunting on decel " ?Would say, specifically, the revs would hang when you lifted your foot at say, 50 - 60 kph?Yes as you described and engine braking is delayed. As Danny mentioned fuel is added despite the pcm not knowing...root cause is scaling and why I noticed a difference between tuners. Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840479 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 8m 3d Gender: Male Location: Melb Posted 12/03/09 08:52 AM Author Share Posted 12/03/09 08:52 AM that decel hunting you so call can be address by disabling the Decel Tip-out.. setting it to 0=)Also guys, this isnt a Drilled injectors vs Deka injectors.I just highlighted this fact that when shops scale injectors, they do not alter the Battery Offset table, which essentially is the open time. Deka's dont need as much "opening time" as Bosch injectors. This is why people say deka's suck because they have sh*t idles due to being so rich, or not having enough pcm resolution to adjust Previously, Setting up this table would have been impossible without the specification sheet from FORD Racing. But the value file that sct provided was "close" to whats required, albiet for only 39.5psi, not 4bar. So it still required modification to the slopes as well as the Offset battery comp table.Also keep in mind, the High slope and Low slope may need some alterations to suit your application. They are a GUIDE only. But it should be withing 10% of commanded AFR's.My car, since I am running united 100, has 10% ethanol. Being that, I have also altered the "Stoich AFR ratio for lambda 1" under the Fuel scalars to 14.1 instead of 14.64. My High slope scaler is also around the 0.0192 mark (not 0.0203). As it ran a little leaner than commanded AFR. Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840496 Share on other sites More sharing options...
_Spin_ Donating Members 695 Member For: 17y 2m 9d Posted 12/03/09 09:23 AM Share Posted 12/03/09 09:23 AM IH8TOADS said: Yes as you described and engine braking is delayed. As Danny mentioned fuel is added despite the pcm not knowing...root cause is scaling and why I noticed a difference between tuners.My car has drilled injectors ( FWIW ) and does this. It really sh!t`s me.. Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840533 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 8m 3d Gender: Male Location: Melb Posted 12/03/09 09:28 AM Author Share Posted 12/03/09 09:28 AM Wouldnt say its the drilled injectors doing it.. Under "Accelerator Pump"Change the "Accelerator Pump Filter for Tip out" to 0.000000 Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840539 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 4m 15d Gender: Male Location: Melbourne Posted 12/03/09 09:28 AM Share Posted 12/03/09 09:28 AM I remember when the scaling was changed on my car with my Dekas, we could all smell the difference in the exhaust as soon as the car was started. It was quite an incredible eye opener! Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840540 Share on other sites More sharing options...
_Spin_ Donating Members 695 Member For: 17y 2m 9d Posted 12/03/09 09:47 AM Share Posted 12/03/09 09:47 AM FWIW stand for = For whats its worth. I wasn`t suggesting it was the injectors, merely that my car has them.I`ve read this thread with great interest,Why, would a car ( lets say, oh.. mine? ) begin to exhibit this hunting - running on behaviour after a tune?Okay, it`s in the scaling, acelerator pump settings or somewhere, but why does it need to be changed after the tune? What change cause this new unwanted aspect? Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840572 Share on other sites More sharing options...
RIPGMH Donating Members 302 Member For: 20y 9m 6d Gender: Male Location: Sydney Posted 12/03/09 09:53 AM Share Posted 12/03/09 09:53 AM Very interesting and infotmative write up , hope other tuners atleast read this post Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840587 Share on other sites More sharing options...
Mr Man Mad Scientist Member 816 Member For: 20y 4m 16d Gender: Male Location: Vic Posted 12/03/09 10:15 AM Share Posted 12/03/09 10:15 AM very informative write-up Danny for the record I have Deka's tuned by Danny and my idle is just as good as it was stock, and my cold starts are perfect as well... Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840624 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 6d Gender: Male Location: OZ Posted 13/03/09 12:16 AM Share Posted 13/03/09 12:16 AM Headsex said: Wouldnt say its the drilled injectors doing it.. Under "Accelerator Pump"Change the "Accelerator Pump Filter for Tip out" to 0.000000.....ahhhh so that's what it was Link to comment https://www.fordxr6turbo.com/forum/topic/55584-why-tuners-hate-60lb-siemens-dekas/page/2/#findComment-840917 Share on other sites More sharing options...
