Boost And Oil Pressure Sensors.....
RegSpec
  • Cruise Control
  • Member For: 17y 10m 28d
I scored a set F6 gauges for my car, and have to drill and tap a port for the boost sensor.
Then, I checked the oil press. sensor and it looks like the same thread......
Does anybody know what thread they are?.....I thought they were 1/8 NPT but tried a plug to fit and
no-go :talktohand:
Edited by BionicXR6T
  • Lost Member
  • Member For: 16y 3m 20d
I fitted mine on the weekend and the thread on the oil pressure sensor is 1/4 x 18 NPT. Male thread on the sensor and female in the hex adaptor to the block. The Male threads on the turbo oil screen hex fitting are 1/4 x 18 NPT on one end and M14 x 1.5p on the other end. Obviously the NPT goes into the block and the M14 goes into the hex adaptor which goes to the oil pressure sender unit. I put an extension between the hex adaptor and the oil pressure sender to tee off for my new gauge sender which has a 1/8 x 27 NPT male thread on the sender unit. Hope I didn't get too wordy and hope this helps. All the best with it.
cheers.
  • 1 month later...
  • Member For: 15y 9m 28d
cheers.
when you fitted it did you need to drain the oil?
  • 6 months later...
  • Member For: 17y 2m 15d
Hey guys hope someone can help me here. I just replaced the oil sensor on the sandwhich plate(for my guages) because it was melted. There was no thread tape on the old one so I didn't put any on the new one. Now its leaking a bit of oil. Is there a special type of thread tape or sealant that I use?
Many Thanks Pete
