  • Member For: 21y 11m 19d
thanx 4 that
just did it and still no change
im headinbg down to CREATD motorsports on sat and askin 4 there opinion n booking it in
for the flapper and bigger actuator :)
Edited by ford_freako
  • Member For: 19y 2m 6d
boost going to the actuator opens the wastegate, if you have a split hose or the hose has fallen off this will give you this problem.
also the boost solonoid if its jammed shut, a simple test would be to put a piece of vacume hose from the turbo compressor housing directly to the waste gate actuator, this should give you 5 psi or so.
if your car still over boosts with the hose directly to the wastegate its safe to assume your wastegate is jammed or actuator is stuffed.
  • Member For: 18y 3m 16d
Check your vacum hose on the front of your turbo, I had this problem about 3 months ago, but my t hit 20psi..
Changed the hose and its all good now..
but did urs make luke a puttin noise through the exhaust
if so
where is this hose
and where does it lead to?
