1989mitty Member 13 Member For: 15y 6m 11d Posted 10/03/09 02:07 AM Share Posted 10/03/09 02:07 AM Hey guys im new to this forum and I dont even own a xr6 turbo but my mate has a bf xr6 ute one of them ripcurl editionsIm after a list of part I need to convert a xr6 n/a to turbo, I have seen other post with alot of good info , but I wanted to start a fresh thread,so if someone could post the parts I need and even a picture so I can just sight whats needed.Im bidding on a bf xr6 cross over on ebay at the moment from a typhoon , this is where the air intake come in and than to the turbo and also the intercooler is this right .Any help would be good thanksHe cant sell his ute and buy a turbo BTW so a converstion is needed Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 3m 26d Gender: Male Location: Melbourne Posted 10/03/09 02:10 AM Share Posted 10/03/09 02:10 AM Search the N/A section mate, theres plenty of info from people who have done it. Also google Snort performance they have a kit which I've been looking into atm. Link to comment Share on other sites More sharing options...
SubJimbo ŠύЂפֿĺmβø ™ Donating Members 1,216 Member For: 16y 8m 19d Gender: Male Location: Melbourne Posted 10/03/09 02:18 AM Share Posted 10/03/09 02:18 AM Just buy a turbo >.> Link to comment Share on other sites More sharing options...
1989mitty Member 13 Member For: 15y 6m 11d Posted 10/03/09 02:18 AM Author Share Posted 10/03/09 02:18 AM (edited) Yeah checked out that website im looking at staying as stock as possibleChecked out all the posts but as im not ford minded im not sure what all the parts are ,I know I need a intercooler setup with cross over section and a turbo and manifold.Subjimbo my mate cant sell his ute and just buy a turbo so he needs to do a converstion Edited 10/03/09 02:26 AM by 1989mitty Link to comment Share on other sites More sharing options...
SubJimbo ŠύЂפֿĺmβø ™ Donating Members 1,216 Member For: 16y 8m 19d Gender: Male Location: Melbourne Posted 10/03/09 02:26 AM Share Posted 10/03/09 02:26 AM I'm assuming with the 1989 part in your name, and wanted to keep it as 'stock' as possible, You are on your P's.. save yourself the trouble and wait until you have your full licence and look for a XR6T, They will be quite cheap by then second hand! If you do the conversion, You may loose your car/licence if you get pulled over. Link to comment Share on other sites More sharing options...
1989mitty Member 13 Member For: 15y 6m 11d Posted 10/03/09 02:38 AM Author Share Posted 10/03/09 02:38 AM Your spot on im not old enough for a turbo but this isnt my car its a friends who just got his full licence and ford under warranty just put a new engine in his ute cause they put the wrong oil in it , so hes not going to buy a turbo engine and do a swap cause it would be putting a older engine in , I just need to know every part needed to do the swap and pictures if possilbe Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 3m 26d Gender: Male Location: Melbourne Posted 10/03/09 02:46 AM Share Posted 10/03/09 02:46 AM Ok, people can add all the little stuff to this if/when I miss something.TurboHot side pipingCold side pipingTurbo manifoldInjectorsFuel pumpTurbo compCoolerValve springsGearbox/clutch (when old one sh*ts its pants) Link to comment Share on other sites More sharing options...
P4N1C Member 26 Member For: 16y 7m 4d Gender: Male Location: Tullamarine, Melbourne Posted 10/03/09 02:54 AM Share Posted 10/03/09 02:54 AM The following is not a full turbo conversion, its simply a bolt on method which retains as much factory components as possible. You'll still need to get the car flash tuned on dyno to correct ignition timing and AFR. Safely, you can only run a moderately low boost level of around 4-5 PSI. You'll also need to drill and tap your oil pan for oil return. You can do this with the oil pan on but its not hard to remove the oil pan without dropping the motor out. If you decide to drop the oil pan, then include the price of a oil pan gasket.Just working off the top of my head. You'll need the following...Major Components:1. Turbo2. Dump Pipe3. Turbo Exhaust4. Cross Over Pipe5. Turbo Coil Cover6. Turbo Fuel Regulator (400kpa)7. Spark Plugs (NGK BKR6EIX-P)8. Turbo Airbox (Lower half only)Heatshields:1. Exhaust Manifold2. Exhaust Manifold Heatshield3. Steering Shaft Heatshield4. Engine Mount HeatshieldWater and Oil Lines:1. Heater Pipe Return (From thermostat housing) **4spd automatic and manual are the same, however 6spd automatic is different part number.2. Heater Pipe Feed (From water pump. BA and BF are slightly different so again make sure you order the right one. No difference between 4spd, 6spd or manual)3. Water Return (From heater pipe to water outlet on turbo)4. Water Return (From heater pipe to water inlet on turbo)5. Oil Feed (From oil switch to oil inlet on turbo)6. Oil Return (From oil pan to oil outlet on turbo)Along with oil and water lines, you'll need gaskets and washers for each oil/water line.Turbo Plumbing:1. Cold Side Pipe (From cross over to turbo inlet)2. Charged Pipe (Rubber pipe from turbo outlet to alloy)3. Intercooler Inlet Pipe (Rubber pipe from alloy to intercooler inlet)4. Intercooler Outlet Pipe (Rubber pipe from intercooler to cross over) Link to comment Share on other sites More sharing options...
1989mitty Member 13 Member For: 15y 6m 11d Posted 10/03/09 11:34 AM Author Share Posted 10/03/09 11:34 AM Thank you so much mate that's everything I need I can start looking into it cheersThose turbo crossovers the 4 pipes what are they for looking straight on top right is from air box bottom right to intake top left from turbo and bottom left from intercooler?shouldnt it go from air box to turbo from turbo to intercooler and than back to intake ? Link to comment Share on other sites More sharing options...
P4N1C Member 26 Member For: 16y 7m 4d Gender: Male Location: Tullamarine, Melbourne Posted 10/03/09 02:47 PM Share Posted 10/03/09 02:47 PM (edited) The cross over pipe configuration looking at it from a bird's-eye point of view, is the following:Top Right - To AirboxBottom Right - To Throttle BodyTop Left - To Turbo Inlet (plastic pipe)Bottom Left - To Charged Plumbing (after intercooler)Where are you located? Edited 10/03/09 04:10 PM by Dagabond Link to comment Share on other sites More sharing options...
