ROB83R Member 1,632 Member For: 8y 10m 24d Gender: Not Telling Location: Radioactive wasteland Posted 21/01/17 01:50 AM Share Posted 21/01/17 01:50 AM Worth a try but they'd be for the elec seat and airbag I reckon. Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629116 Share on other sites More sharing options...
xr64rj New Member 10 Member For: 8y 2m 23d Posted 21/01/17 01:55 AM Share Posted 21/01/17 01:55 AM Hi ROB83r Yes that was just a stab in the dark from a guy at work , we are just trying to think of any ridiculous reason why it wont fire up, this doesn't look good as the first step in a huge rebuild plan? Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629117 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 16d Gender: Male Location: Perth Posted 21/01/17 02:16 AM Share Posted 21/01/17 02:16 AM Neutral switch on box?? Are both connections on the rear of the dash all the way in. are all the connections on the ICC in and pushed in hard. Did you need to reset the ICC self align connector Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629119 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 5m 3d Gender: Male Location: left right out Posted 21/01/17 03:14 AM Share Posted 21/01/17 03:14 AM +1 for the connectors on the ICC as Arronm said, in particular the white plug on the back . If you grab the part of the white plug that's attached to the car and gently pull it towards you you will see the cam locks (black from memory) roll out and lock the plug sticking out. When you reinstall the ICC it will line up and reset itself. Be extra carefull to install it square, and check all pins are straight as they bend easily if its off centre a bit. 1 bent pin can make all dash lights dissappear, door open light flicker etc- all problems my alarm guy encountered. Pic of bent pin for Keith 1 Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629120 Share on other sites More sharing options...
xr64rj New Member 10 Member For: 8y 2m 23d Posted 21/01/17 09:05 AM Share Posted 21/01/17 09:05 AM Hi I think its in properly as everything on the ICC works, I tried to reload my custom tune with the flash tuner but now its showing an error. but I left my reading glasses at work (getting old sucks), but I noticed that the air bag light on the dash was flashing 5 on then 2 on. does this mean anything. Getting to the stage where I will ask the ford dealer to come out and fix it Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629138 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 16d Gender: Male Location: Perth Posted 21/01/17 11:25 AM Share Posted 21/01/17 11:25 AM Does your seats have air bags?? Connect the seat back up Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629160 Share on other sites More sharing options...
xr64rj New Member 10 Member For: 8y 2m 23d Posted 21/01/17 04:50 PM Share Posted 21/01/17 04:50 PM Hi Can't sleep, drivers seat put back in, doesn't have air bags(haven't put passengers seat in) but I'll try anything at this stage, tried to reflash car, now showing reload failure code 1034 on the SCT 3, pulled ICC out again and checked pins in the back of the unit, all are straight, refitted ICC, now showing system code error on the ICC screen. Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629233 Share on other sites More sharing options...
Kyananthony New Member 5 Member For: 8y 10m 10d Posted 21/01/17 09:29 PM Share Posted 21/01/17 09:29 PM Ok you need to simply go back over all the connectors and ensure they are all pushed in correctly. It is so simply to miss one by not clicking it it! Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629234 Share on other sites More sharing options...
xr64rj New Member 10 Member For: 8y 2m 23d Posted 22/01/17 07:19 AM Share Posted 22/01/17 07:19 AM Hi all Fitted passenger seat, air bag light now goes out, security code still on ICC, undid all cable connections and put them back, still no starting. I give up, I'll go to the dealer tomorrow and ask if they can fix it. Thanks for everyone's help I know it's hard when you can't physically see the work. Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629280 Share on other sites More sharing options...
xr64rj New Member 10 Member For: 8y 2m 23d Posted 25/01/17 04:29 AM Share Posted 25/01/17 04:29 AM Hi all Just thought I keep everyone up to date, Ford wont come and look at car at my place (which is 400m up the road) I arrange a tilt tray to take it there($110) Monday as they said the would work on it Tuesday, however when I took it there now they can't work on it till Friday as it needs diagnostics run on it, I feel now that I'm going to be ripped off, does anyone know what a reboot of the computer should cost. Link to comment https://www.fordxr6turbo.com/forum/topic/55503-how-to-remove-dash-babf/page/6/#findComment-1629736 Share on other sites More sharing options...
