  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 8d
Fuse? Check all of the footwell large connectors to make sure they are all of the way home and make sure the under dash connections that you disconnected are correctly reconnected.
  • New Member
  • Member For: 8y 10m 16d
Very  very late comment mate and I hope your still a member BUT awesome job on the write up I'm attempting to do my wife's tomorrow and she hates spare parts when I do a job on her car ??????
  • 2 months later...
  • Member For: 16y 8m 23d
Great write up bud.  Had to do a HIM changeover yesterday.  Had the problem of the Heater/ Aircond fan staying on after you turn the ignition off.  Started at 10am and finished at 8pm.  All works a treat.
  • 5 months later...
  • New Member
  • Member For: 8y 2m 29d
Hi all
Followed the original post and was a great help, all back together and everything works but car wont start, (car has ford starter button, has power but wont crank). checked all connections and everything seems good. any suggestions. also checked all fuses. this is pi88ing me off.
Thanks Randall
  • New Member
  On 25/06/2015 at 12:38 AM, Ralph Wiggum said:
1/2 an hour before tackling air bags is the rule so just disconnect the battery before you start. ICC will display "CODE" when you first power it up afterward but after a couple of key cycles and waiting a couple of minutes with the key on it will come good.
Expand
I have had my battery disconnected for a few weeks on my BA wagin and reconnected it all ran just fine no issues at all with anything!!! Gear changes everything!!
  On 20/01/2017 at 9:47 AM, xr64rj said:
Hi all
Thanks Randall
Expand
More info needed mate! Is it manual or auto? Does dash light up?
  • Moar Powar Babeh
  • Member For: 19y 6m 26d
Expand
OK¡¡¡¡¡
  • Dropping a turd
  • Member For: 17y 5m 22d
The issue you guys are having is you removed the dash from the car, what  you needed to do was remove the car from the dash..
  • New Member
Hi
Its auto, the dash lights up, the starter button lights up, everything in the ICC works, the console is out but its in park, I have the seats out would this make any difference seeing there's 3 plugs in the drivers seat and 2 in the passengers seat.
Thanks
