  • Member For: 20y 10m 16d
OK, I have $1500 to spend on a custom tune package. I would love to get to the magic 300. The only mods I have done are, BNC Filter, removed middle muffler and Exedy heavy duty cushion button clutch and flywheel. Has anyone got any recommendation? Are there any sponsors that can help.
https://www.fordxr6turbo.com/forum/topic/55469-1500-to-spend/
  • Replies 32
  • BOOST
  • Moderating Team
  • Member For: 21y 9m 13d
Plenty of sponsors that can help. Injectors and tune would probably be a bit more than 1.5k. If you got the edit alone youd be about 1k and that should see 235rwkw to 265rwkw
  • Member For: 19y 11m 11d
1500 will not get you to 300kw, but as already said, edit and injectors are a good start.
  • Member For: 18y 2m 15d
1500 wont get you far in the scheme of things. no offence!
a custom tune and xcal2/3 will be most of your 1500 gone! and that should see you anywhere from 230rwkw - 250rwkw depending on how good your standard valve springs and injectors hold up!
that's what I would be starting off with anyways, then saving up for valve springs, injectors and a fuel pump!
  03XR6T said:
Flash 3 - $650
Tune - $650
Injectors - $500
Cat - $300
Total - $2100
and labour for fitting injectors and the cat and youve gone over budget.
where can you pick up an xcal 3 for 650? pm me.
