Got The Ute Re-tuned....
ktm07
  • Member For: 16y 10m 13d
dyno and I left quick smart , now extreme tunes my car never had an issue at all car ran faultless ,so after being told that the gas injectors were not compatable with dekas,tuner was telling me the inj pulse wasnt enough (as gas injectors piggy back the petrol intector pulse) I removed them and refited the std injectors and flashed it back to standard tune and reluctantly returned to the first tuner for a retune no luck ,car was better on gas but not fixed .
so after talking to some other intallers I turned up on the doorstep of force feed gas in jandakot owner has a 500rwhp twin turbo vy ute on straight gas
within 5 mins on road test he told me that the gas ecu wasnt recieving a map sensor signal they were booked for about two months so I waited for them to get a opening and in it went
I left car with him then got a phone call saying its all sorted ,told me they had to move position of injectors so that they were closer to manifold ,
and that one of the nozzles drilled into the manifold was partialy blocked,
on picking the car up it was the same to drive on gas as petrol ,on boost it was mint I even think its a bit smoother on lpg on boost
so im of to extremes for a retune on the std injectors ,then back for a retune on gas force fed recon 250rwkw is the limit of system so ill get simon to get as close as that , as it ran low 13,s with 246rwkws on a sh*t track ,so if I can get at least that again on lpg ill be rapt
so im of now to enjoy the rewards of walking out of bp only giving them a 18-22 dollar donation
car is booked in for a retune on std injectors next month hopefully get close to the 245rwkw it had before with the dekas fitted
Edited by GCTXR6
a cut and paste from my thread :finger: basicly the only drama I had was a installer who had nfi :roflmbo:
had my car put on vapour injection lpg last year by an installer that will remain nameless and had issues right from the start ,
the car had deka injectors fitted and a 246rwkw extreme tune , the car would start and run on petrol then at 45degrees water temp swap to gas , no problems economy was great and every thing other than full thottle over 3500rpm it was great but the gas system was leaning out in the top end and he couldnt sort it ,after countless return visits and watching him dynoing it still on the noise into the 15afrs ,so in an instant I had him take it of the dyno and I left quick smart , now extreme tunes my car never had an issue at all car ran faultless ,so after being told that the gas injectors were not compatable with dekas,tuner was telling me the inj pulse wasnt enough (as gas injectors piggy back the petrol intector pulse) I removed them and refited the std injectors and flashed it back to standard tune and reluctantly returned to the first tuner for a retune no luck ,car was better on gas but not fixed .
Edited by GCTXR6
