  • Member For: 17y 11m 11d
Curiousity more than anything.
But is it possible to fit one of those shift alert beepers (lol I know its not called this) from the FPV's to other models?
Also if you know, what parts are required and approx. how much?
Thanks
https://www.fordxr6turbo.com/forum/topic/55333-shift-alert-beeper/
  • Replies 25
  • Just a large member member
  • Member For: 16y 6m 18d
mate what dose it do.if you work shift work dose it wake you if your a sleep in the car or something like that.
ok dunno if your being serious or not :crybaby:
but just before you hit the rev limiter an "alert" sounds goes *beep* *beep* *beep* *beep* *beep* *beep* alerting you to the fact that you are about to hit the rev limiter.
yes I know its got alot of wank factor about it. but I love the wank factor :bye:
do you know what fpv model has them,first I heard of them.Cheers Nick
  • Go Pies!!!
  • Member For: 17y 2m 17d
You can buy these in short kit form - check with your local Jaycar!
The F6's had them in there as well (as previously mentioned above). (think it was an option but and not aval with the ZF)...
You could also just add a new tacho in with a shift light and convert the shift light (or piggy back off it) to a buzzer...
As for the wank factor - I think two dol'la two dol'la might be a cheaper solution! :nuts:
Edited by smicky
  • Formerly XR6NA
  • Member For: 19y 5m 4d
I think only the manual's get it.
  • Member For: 21y 8m
I have had one fitted to my previous supercharged xr8. Got it from shiftkits.com. If you want it you can have it for $60 plus postage!
Has the beeper and can also fit shift light to it and can be set at any rpm you want via laptop.
