Brake Upgrade - Advice On What To Get From Pbr ?
kdee10
  • Member For: 17y 8m 17d
If you want upgrade your rears as well I would look at getting the rears of a terri or a Bf, the rears are vented unlike the PBR kit and the stock ba discs.
The rears from the PBR Muscle Kit on mine are slotted so I thought they were vented too.
All I know is if you can get the complete kit like I did for around $1500 then you cant go wrong.
  • iTs alL DaRDy........
  • Member For: 17y 2m 23d
henry, as the majority of braking is done up front, chances r that shudder is from the front as they will be working harder and getting hotter, so yeah your good to replace just the fronts but if you have the coin do the rears as well so they match :)
  • Member For: 16y 8m 25d
:spoton:
The rears are definitely not vented. They are 303mm x 16mm solid discs. It doesnt matter that they are slotted.
I got a whole used kit in the garage looking for a new owner :nerd8:
  • 2 weeks later...
  • Inactive Members
  • Member For: 15y 8m 6d
Hi all,
I am fortunate to have a father in law that works for PBR, so I can pretty much get anything I want from them.
I want to upgrade the brakes on my 2005 BA MkII XRT, what would be your suggestions for the best setup, keep in mind I do not want to spend a fortune.
You advice would be very helpful.
Cheers.
Mate is it possible for you to contact me asap I want some PBR disc rotors and cant find anywhere that stocks them I am in QLD
Cheers
  • 12 years later...
  • Member For: 3y 6m 5d
Cheers
I'm also in need of discs for this package. Has anyone got any ideas or luck sourcing them? There is a front available through DBA only though I do want front and rear to match.
