Maximus Member 1,627 Member For: 18y 2m 9d Gender: Male Location: Slip Sliding Away Posted 08/03/09 11:14 AM Share Posted 08/03/09 11:14 AM seventytwo said: If you want upgrade your rears as well I would look at getting the rears of a terri or a Bf, the rears are vented unlike the PBR kit and the stock ba discs.The rears from the PBR Muscle Kit on mine are slotted so I thought they were vented too.All I know is if you can get the complete kit like I did for around $1500 then you cant go wrong. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/page/2/#findComment-837976 Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 17y 8m 15d Gender: Male Location: Adelaide Posted 08/03/09 11:47 AM Share Posted 08/03/09 11:47 AM henry, as the majority of braking is done up front, chances r that shudder is from the front as they will be working harder and getting hotter, so yeah your good to replace just the fronts but if you have the coin do the rears as well so they match Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/page/2/#findComment-838002 Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 2m 17d Gender: Male Location: Blacktown! Posted 08/03/09 12:11 PM Share Posted 08/03/09 12:11 PM Maximus said: The rears from the PBR Muscle Kit on mine are slotted so I thought they were vented too. The rears are definitely not vented. They are 303mm x 16mm solid discs. It doesnt matter that they are slotted. I got a whole used kit in the garage looking for a new owner Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/page/2/#findComment-838027 Share on other sites More sharing options...
F6madness Inactive Members 1 Member For: 16y 1m 28d Posted 21/03/09 11:33 PM Share Posted 21/03/09 11:33 PM kdee10 said: Hi all, I am fortunate to have a father in law that works for PBR, so I can pretty much get anything I want from them.I want to upgrade the brakes on my 2005 BA MkII XRT, what would be your suggestions for the best setup, keep in mind I do not want to spend a fortune.You advice would be very helpful.Cheers.Mate is it possible for you to contact me asap I want some PBR disc rotors and cant find anywhere that stocks them I am in QLD Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/page/2/#findComment-846438 Share on other sites More sharing options...
YellowTurbo Member 163 Member For: 18y 8m Gender: Male Location: Darwin Posted 25/03/09 02:05 AM Share Posted 25/03/09 02:05 AM Get the 6 spot jobs but you'll need a xr 18 as a min and they won't fit behind most rims.expensive too. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/page/2/#findComment-848357 Share on other sites More sharing options...
Sunburst XR50T New Member 2 Member For: 3y 11m 27d Posted 25/05/21 06:50 AM Share Posted 25/05/21 06:50 AM On 21/03/2009 at 11:33 PM, F6madness said: Mate is it possible for you to contact me asap I want some PBR disc rotors and cant find anywhere that stocks them I am in QLD Cheers Expand I'm also in need of discs for this package. Has anyone got any ideas or luck sourcing them? There is a front available through DBA only though I do want front and rear to match. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/page/2/#findComment-1705018 Share on other sites More sharing options...
finnas Gold Donating Members 105 Member For: 15y 4m 8d Posted 25/05/21 07:16 AM Share Posted 25/05/21 07:16 AM Just because of your name :P Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/page/2/#findComment-1705020 Share on other sites More sharing options...
