kdee10 Member 14 Member For: 16y 3m Posted 04/03/09 09:43 AM Share Posted 04/03/09 09:43 AM Hi all, I am fortunate to have a father in law that works for PBR, so I can pretty much get anything I want from them.I want to upgrade the brakes on my 2005 BA MkII XRT, what would be your suggestions for the best setup, keep in mind I do not want to spend a fortune.You advice would be very helpful.Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/ Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 17y 7m 21d Gender: Male Location: Adelaide Posted 04/03/09 09:51 AM Share Posted 04/03/09 09:51 AM nothing from pbr bud lolpitty he doesnt work for dbamost members go for dba 4000 slotted rotors and some good pads I.e bendixI have and they work great Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-835382 Share on other sites More sharing options...
aiboart Member 665 Member For: 20y 3m 11d Posted 04/03/09 10:33 AM Share Posted 04/03/09 10:33 AM OK here are some suggestions1- / BA serie FPV F6, GT, etc standard brakes (also known as Ford Premium and PBR aftermarket)This is seriously well sorted powerful and light weight brake package. It is the Factory system.It consists ofnew calipers front onlyslotted discsnew pads (braided lines - aftermarket version only)1.2/ A step up in heat tolerance and heat pumping capacity is to forgo the PBR discs and buy DBA discsDBA 5000 front slotted (only). This is a 2 piece disc, lighter, better heat performance, cheaper to replace, the best there is short of ceramic.DBA 4000 rear slotted (only) one piece disc1.3/ Whilst the PBR pads are frankly amazing there are alternatives.Ferodo Formula - more temperature linear than the PBR's - less impressive but possibly better Ferodo DS2500 - more temperature sensitive, somewhat like the PBR's, not sure to what extent - higher ultimate grip2. PBR also make some impressive brakes that will fit the XR6 Turbo.At least one of the former members had a set fitted to his XR6T.IIRC these were,6 pot with an individual pad per pot on the front4 pot with an individual pad per pot on the back.Big discs, two piece front.Possibly ZR-06 series brakesOption 1 is all you will ever need, under any conditions, unless your car is a modded monster.Adding the DBA 5000 series discs really puts the braking system capacity way out in the stratosphereOption 2 is simply overkill and so too much weight and moment from iron discs and calipers... and really, totally cool... see if you can find some affordable ceramic discs and for it Regards,aa Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-835408 Share on other sites More sharing options...
Maximus Member 1,627 Member For: 18y 1m 16d Gender: Male Location: Slip Sliding Away Posted 04/03/09 10:47 AM Share Posted 04/03/09 10:47 AM Hey Kdee10, I have a mate that works for PBR too.He got me the Muscle Pack which was $1450 (I think) then got Nizpro to install them for $250.http://www.pbrperformance.com.au/performance.htmIt was all 4 discs, Calipers, Pads, Braided Lines and Fluid. RRP is closer to $3K fully installed and they work a treat.They are the same that are on the FPV's standard.I could have gone the M Series upgrade for about $4000 through him. RRP is over $6K if I remember right.These are the same brakes that are on the new Corvette.http://www.pbrperformance.com.au/M-SeriesUpgrade.htmThere is no use paying full price for the DBA's if you can get the PBR's this cheap. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-835422 Share on other sites More sharing options...
kdee10 Member 14 Member For: 16y 3m Posted 04/03/09 11:17 AM Author Share Posted 04/03/09 11:17 AM Thanks a lot for the response guys, I am thinking that the Muscle pack might be the way to go, seeing I can get them for a greatly reduced price, also, people her work at PBR get an allowance each year so if the father in law is really nice to me he may just wack them on his allowance !!! Now that would be sweet !!Thought that I would start with upgrading the brakes, then onto the go fast parts later, as the brakes in this model are crap... as I have heard?Cheers all, appreciate the advice. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-835439 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 8m 8d Gender: Male Location: Broady, Melbourne Posted 04/03/09 11:32 AM Share Posted 04/03/09 11:32 AM Don't waste your cash. Rear callipers in the "muscle pack" are the same as standard. Just get the C6 calliper, braided lines, rotors and pads from PBR and if you know someone inside, you'll aslo be able to get the different brake line bracket. Ford's retail on that piddly piece of metal is over $60 and about $42 trade. The standard bracket (about 4 cm less metal) is about $2.30. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-835451 Share on other sites More sharing options...
kdee10 Member 14 Member For: 16y 3m Posted 04/03/09 11:52 AM Author Share Posted 04/03/09 11:52 AM I would get the c6 calipers etc which I understand to be the M-series upgrade from PBR, but I do not have 18inch rims, only the standard 17's which come with the car, so that setup would not fit unfortunately. When I do decide to get these from him, I need to give him all the part numbers so he will get me the correct parts. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-835465 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 9m 19d Gender: Male Location: The 8th Dimension Posted 04/03/09 12:25 PM Share Posted 04/03/09 12:25 PM Don't waste your cash. Rear callipers in the "muscle pack" are the same as standard. Just get the C6 calliper, braided lines, rotors and pads from PBR and if you know someone inside, you'll aslo be able to get the different brake line bracket. Ford's retail on that piddly piece of metal is over $60 and about $42 trade. The standard bracket (about 4 cm less metal) is about $2.30.If you want upgrade your rears as well I would look at getting the rears of a terri or a Bf, the rears are vented unlike the PBR kit and the stock ba discs.Picked up mine from FTG salvage for about $400, just dont forget to grab a set of braided hoses for the rear from PBR as well. Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-835475 Share on other sites More sharing options...
howitzer85 Member 241 Member For: 18y 2m 6d Gender: Male Location: The marsh... Posted 05/03/09 09:12 AM Share Posted 05/03/09 09:12 AM I would get the c6 calipers etc which I understand to be the M-series upgrade from PBR, but I do not have 18inch rims, only the standard 17's which come with the car, so that setup would not fit unfortunately. When I do decide to get these from him, I need to give him all the part numbers so he will get me the correct parts.the c6's aren't the m-series, they are the ones in the other pack Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-835975 Share on other sites More sharing options...
Henry Member 180 Member For: 22y 2m 22d Gender: Not Telling Posted 08/03/09 10:47 AM Share Posted 08/03/09 10:47 AM Is the shudder due to the front or the back as well?Just wondering, if its safe to just do the DBA4000 slotted and Bendix Ultimates on the front? I.e. dont want to create any balance issues.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/55305-brake-upgrade-advice-on-what-to-get-from-pbr/#findComment-837963 Share on other sites More sharing options...
