RHR BOOST Moderating Team 5,698 Member For: 21y 7m 13d Gender: Male Location: Southern Highlands NSW Posted 03/03/09 08:02 AM Share Posted 03/03/09 08:02 AM is there any foreign material in the oil. Have you check the spark plugs for metallic flakes Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834548 Share on other sites More sharing options...
neo Member 376 Member For: 17y 1m 7d Gender: Male Location: The Ville Posted 03/03/09 08:39 AM Author Share Posted 03/03/09 08:39 AM took the plugs out there fine no flakes I can see. Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834592 Share on other sites More sharing options...
millers Member 113 Member For: 16y 10m 17d Posted 03/03/09 08:42 AM Share Posted 03/03/09 08:42 AM I have heard this ticking noise and as far as I can tell it seems to be coming from the head around the back on the intake side.the ticking gets faster with higher RPM and neo thinks it might get a little quieter when when the engine is warmed up (didnt leave it running too long when I was there... its broken enough as it it )havent dropped the oil out of it, but what is left in the head (and all over me after playing) the oil seems pretty clean. not sure how old the oil is though. neo?spark plugs came out last night and dont look too badI cant think of a way to describe the noise. to me its half way between a ticking and a knocking. its definately coming from towards the back of the engine though Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834597 Share on other sites More sharing options...
neo Member 376 Member For: 17y 1m 7d Gender: Male Location: The Ville Posted 03/03/09 09:04 AM Author Share Posted 03/03/09 09:04 AM oil is about 5000 old it was going to go for a service.say I do get a replacement engine with low km anyone see why cant swap it and them find out and build up my busted one. Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834625 Share on other sites More sharing options...
millers Member 113 Member For: 16y 10m 17d Posted 03/03/09 09:22 AM Share Posted 03/03/09 09:22 AM also another question with the swapping...as far as I know the BA ecu is not gunna be able to run the BF/BFII engine due to the varible cam timing in the later engines.if the ecu is swapped to one that will run the engine I understand the ICC will have to be reprogramed by Ford? also will doing this change the VIN and cause an xcal2 to stop working? Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834654 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 11m 14d Gender: Male Posted 03/03/09 09:26 AM Share Posted 03/03/09 09:26 AM millers said: also another question with the swapping...as far as I know the BA ecu is not gunna be able to run the BF/BFII engine due to the varible cam timing in the later engines.if the ecu is swapped to one that will run the engine I understand the ICC will have to be reprogramed by Ford? also will doing this change the VIN and cause an xcal2 to stop working?If its just a short he will be fine I know alot of people with BF motors in Ba's Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834662 Share on other sites More sharing options...
neo Member 376 Member For: 17y 1m 7d Gender: Male Location: The Ville Posted 03/03/09 10:20 AM Author Share Posted 03/03/09 10:20 AM what about BF bottom with BA head or BF head with BA cam gears? should be like a stronger BA. I am working with limited money at the moment I could save up but id rather a quick fix so I can at least drive it instead of the misses fesita. then build my old one up. Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834730 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 9m 30d Gender: Male Location: Earth Posted 03/03/09 10:22 AM Share Posted 03/03/09 10:22 AM Geez, you guys seem to be going all out before you find out what's actually wrong with it.Could it be as simple as a collapsed lifter?Have you done a compression test on it?Could possibly be a burnt valve? Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834731 Share on other sites More sharing options...
millers Member 113 Member For: 16y 10m 17d Posted 03/03/09 10:37 AM Share Posted 03/03/09 10:37 AM haha you reading this neo? as far as I know his thinking is that it will cost $xxx just to get a mechanic to find out whats wrong with it and that doesnt guarantee a fix, but he can get a new engine for $1500ish and have it installed for a carton + other small misc stuff needed for it. Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834759 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 11m 14d Gender: Male Posted 03/03/09 10:40 AM Share Posted 03/03/09 10:40 AM neo said: what about BF bottom with BA head or BF head with BA cam gears? should be like a stronger BA. I am working with limited money at the moment I could save up but id rather a quick fix so I can at least drive it instead of the misses fesita. then build my old one up.Yeah mate no worries with a Ba head on a bf bottom Link to comment https://www.fordxr6turbo.com/forum/topic/55222-rebuild-vs-replacement-engine/page/2/#findComment-834765 Share on other sites More sharing options...
