Think We're Quick! Nup.
qik1
  • Member For: 17y 10m 9d
DAMN good effort!!!
if it was cheap enough to blow/turbo a Expensive Daewoo and do it properly the right way, I wouldnt be driving a ford!!!
I have a good friend who drives a single turboed (T51R) LS1 Monaro, 6spd manual, Std bottom end who did a 11.06@129 mph!!! on pump fuel!!!
im pretty sure the car was making just on 400rwkw.
im pretty sure that if it was an auto it would have gone a sh*tload quicker!!!
does he/she say how many engines they have gone through????
Edited by The_Bogan
  • Member For: 21y 5m 8d
Yep I'm a fan of anything tuff, powerful, just plain fast, oh and shiny also!
Still love big doose doose (also known as doof doof and oonstt oonstt) custom audio to.
  • Member For: 16y 6m 8d
Its cheaper than what you might think to either turbo or s/c one of these cars. Single turbo kits are around 7k drive in drive out intercooled s/c around 10k. Im sure there are better deals out there but that's what I have found in my itial investigation. Both kits will see you close to 400rwkw on a factory engine. Capa are actually doing drive away packages for the VE V8's at the moment which give you a brand new car, big rims, zorst and s/c for around the same price as what those things were selling for around 12 months ago.
  • Member For: 22y 25d
:pirate:
An LS with a big pipe and MASSIVE cam is one of the best engine notes! and that idle... :drewl:
  • Performance is our business
  • Member For: 18y 8m 19d
If that's the black vy ss ute your talken about, that's Tim.....great bloke he is... his gone through HPF to run that time.
It's Tim's car, he is a good bloke and the work was done at HPF. It ran that time with a lazy 1.7 60ft so if Tim wanted to we could have easy smashed another 2-3 tenths of that with getting the car out of the hole better. Next time the car is out we should be able to drop seconds, not just tenths. :spoton:
must be added that the time was run on race fuel, not sure what it would run on PULP. Impressive though whichever way you look at it!
Lets not forget that Chris from Bluepower's Boss also ran a 10.05@136 unopened stock motor.
So do I think Fords are quick? Yep!
The car was run on Sunoco race fuel, this is the safest way to keep the 10-1 compression engine alive with 15psi. No Boss engine has ever ran that fast unopened stock - period, Bluepower included. :+1:
You will not find a current offer for a single turbo kit anywhere near that price, the kit alone with the Garrett GT4088 journal bearing turbo charger is 7k, not fitted, not landed. You still have to add injectors, map sensor, fuel pump, fitting, tuning, etc. Think 10k plus. Also, these entry kits are not going to give you 400kw at the wheels, think 330 - 350rwkw on an honest, not trying to sell you anything because I make it, dyno.
Contrary to popular belief, 400kw at the wheels out of an LS1 is not as easy as having a poo! You will need at least 14psi of boost on a standard engine and 10-12 psi on a engine with upgraded cam and lower compression. The VE engine is a little easier.
Regards,
Matt
