Help, Aftermarket Deck In Ba Xr6 Turbo
crusty85
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 18y 8m 19d
so where abouts is the esiest accessory wire, do I hav to run from ignition or from the standard icc, where sumbody help
The quickest place is the 12v power supply.
I fully installed a head unit amps and subs in a custom box in like 4 hours in my ba. including running power supply line to battry in the front, its pretty easy work on a falcon.
But on a bma fck took me 2 days nearly.
  • Member For: 15y 11m 26d
yeah falcons r pretty easy we usally allow 6 to 9 hrs to install deck , splits, rear coax, 4 channel amp, mono and subs in a box to fit up on the hump... as for the acc wire you can get it from the 12v outlet of from the white plug next to the fuse box...
have a go take plenty of pics n if you get stuck im sure 1 of us will be able to assist you!!!
  • Donating doesnt allow you to be an idiot!
  • Member For: 17y 11m 6d
CRUSTY
under the drivers feet behind the fuse panel you will find a little plug, this will either be blue or white. In that plug you will find all 3 wires you need to wire up your head unit.
yellow is 12V
black is earth
accessories is black wire with yellow trace
Splice into these wires and theres your wiring done for the head unit.
if you have any other problems at all have a look at my tutorial
http://www.fordxr6turbo.com/forum/index.php?showtopic=44426
Edited by Azid Rush
