  • Member For: 16y 5m 20d
Hey all I just got my 06 bf xr6t 6spd auto and I am looking at getting some mods done in the near future around 300-310rwkw. I am no expert but I am looking at getting injectors, fuel pump, full xforce exhaust and I was looking at just sticking with the standard airbox with typhoon cai and k&n and probably a pw stg 1cooler. But at what point does the airbox, cross over and stock piping become a real restriction? and what boost would I be looking at to achieve my 300-310rwkw with these mods and would an actuator be required to achieve all this??? Any input greatly appreciated :spit:
https://www.fordxr6turbo.com/forum/topic/54686-getting-to-low-300s/
  • flame magnet
  • Member For: 17y 12d
I got 314rwkw with stock crossover. rapid cooler (the best imo), only aftermarket pipes are cold side to x-over. all mods you mentioned plus 12psi actuator. stock zorst with 'hiflo' cat. 16psi down low, then flattens to 15psi. actuator allows minimum boost to its rating, and much more controllable for tuner.
My BF made 295rwkw with injectors, fuel pump, cat & tune on 12psi mate. It ran 12.4 @ 115 or 116mph so the proof of power was there. That was using stock airbox, stock paper filter & stock FPV cooler so with full exhaust, uprated cooler & a tad more boost you should go 310 easy :crybaby:
under battery pipe....so say I got the rapid v2 kit which includes the under batter cai and cold side piping, the cross over is totally removed, and this would lower my boost and temps by much compared to useing stock cross over, piping and airbox and would it really be worth the extra money only chasing low 300s???
  • Cryptic Clothing Company
  • Member For: 16y 10m 18d
I made 310 on just, fuel pump, full exhuast, 60lb injectors and tune
  • Member For: 18y 1m 25d
an after market cai will definately help!!
my car was making 312rwkw with a stock exhaust ( no cat ) monza cooler, standard airbox with f6 snorkel, standard crossovers and standard wastegate and actuator and with a standard 4spd auto.
it all comes down to how good your engine is from factory, if it was a monday tuesday built car or a friday arvo special. every car is different and react differently to different mods! some mods work well on others and some dont!
