newxr Member 279 Member For: 20y 9m 23d Posted 05/07/04 03:30 AM Share Posted 05/07/04 03:30 AM HiConsider 7 bladed computer case fan (60-80mm) in diamter. Specifications read air movement of 30CFM (cubic feet per minute) with pressure of about 6-10mm H2O at 3000RPM.Now attach said fan to model aircraft motor at 21000RPM = (?) 200CFM and 70mm pressure. Now attach 3 said fans together onto bottom of the airbox powered by the battery = 500-600CFM + over 200mm pressure (=about 1/3-1/2 PSI).Extra air and pressure should be good for about 10-15kwTotal cost would be in the oreder of $300idea from - http://www.electricsupercharger.com/YES or Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 11m 25d Gender: Male Location: Sydney Posted 05/07/04 04:31 AM Share Posted 05/07/04 04:31 AM There are 2 things to consider here:The PC fans are not designed to spin at 21k rpm and will most likely fall apart, as well as having 3 fans in sequence will probably produce less airflow than one fan as the turbulence from the 3 fans would cause too much air disruption and make the fans work less efficiently.The second is the power draw to spin these motors. You will find that 3 motors spinning 3 fans will draw several amps of power thus robbing the engine of power it is meant to be producing.In theory it has been done many times, but I have not seen or read about a practical worthwhile example. Link to comment Share on other sites More sharing options...
turbotom Team Bute Donating Members 1,550 Member For: 21y 6m 24d Gender: Male Location: Adelaide Posted 05/07/04 04:50 AM Share Posted 05/07/04 04:50 AM I can't remember where I saw it, but auxilliary engines have been used successfully to drive superchargers for large capacity engines.small two stroke motor used to drive blower for a V12 diesel....developed huge torque gains. Don't remember exact details, but recall I was pretty amazed by its specs.Might have been a marine application??? where constant rpm is appropriate.Electric superchargers have been tried..... general overall loss of power due to inefficiency.... require more power to drive the motor than the gain achieved with the boost provided.Also, like Zap said, the PC fans will not cope with the loads at 21000rpm. I also recall some brainwave was promoting smog pumps from early 70's anti pollution engines as a cheap way of adding a supercharger.Once again, not too much gain due to insufficient air flow.cheers Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 10m 22d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 05/07/04 05:55 AM Share Posted 05/07/04 05:55 AM Sounds like an interseting project, maybe tougher componentry rerquired as the lads are giving your fans a clip over the ear. I reckon Geea could get one on his car by Friday night, pity he's working.Scotty Link to comment Share on other sites More sharing options...
Guest ba XR6 Guests Posted 05/07/04 06:02 AM Share Posted 05/07/04 06:02 AM mmmm but when the car is at idle it still sucks some air, so would it suck faster than a fan could blow at a resonable amount of RPM Link to comment Share on other sites More sharing options...
HellionXR6T I'm Back!! Thats right, long over due! :) Lifetime Members 4,348 Member For: 22y 3m 4d Gender: Male Location: West Brisbane Posted 05/07/04 06:10 AM Share Posted 05/07/04 06:10 AM And here I am wanting to install a supercharger, well there you go. Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 10m 22d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 05/07/04 06:14 AM Share Posted 05/07/04 06:14 AM And here I am wanting to install a supercharger, well there you go. No Wayne, there you goScotty Link to comment Share on other sites More sharing options...
xr6uteboy Member 3 Member For: 16y 9m 20d Posted 03/07/08 06:22 AM Share Posted 03/07/08 06:22 AM Hey guys I am new to this forum I have a ba n/a ute running pacies 4495 comp extractors, magnaflow cat into custom dual exhaust with quad tips. I have a custom air intake and I just wanted to know if anyone knows much about this force flow electric supercharger that says can gain upto 10% more power and save on fuel consumption?cheers and go the n/a's Link to comment Share on other sites More sharing options...
mercuryturbo Oh look.... a real car, with no hair dryer Donating Members 1,724 Member For: 18y 5m 29d Gender: Male Location: Fear and Loathing in Callala Bay Posted 03/07/08 06:33 AM Share Posted 03/07/08 06:33 AM There an absolute Im sure someone smarter than myself will be along shortly to explain why they dont work. Something to do with the power required to pressurise an engine which is far greater than the power these pieces of sh1t emit. Link to comment Share on other sites More sharing options...
PURVIE Sexy Member Donating Members 524 Member For: 18y 1m 29d Gender: Male Location: Berwick, VIC Posted 03/07/08 06:44 AM Share Posted 03/07/08 06:44 AM haha mate IT'S AN ABSOLUTE WASTE OF TIME. Its the same as having a that fake BOV sh*t for n\a cars......but worse.FYI www.sunamiturbo.comIm pretty sure someone on the forum, or friends of theirs bought one, and it broke after driving his car 3 times, haha. And IMO It will probably do more damage, not being able to breathe correctly, etc.Its a farkkkin plastic piece of sh*t mate, and for 300+ bucks I wouldnt waste a further thought on it, save your cash and put it towards something that will actually make difference.Cheers Link to comment Share on other sites More sharing options...
