dolbs Member 7 Member For: 17y 6m 26d Posted 17/02/09 02:28 AM Share Posted 17/02/09 02:28 AM Does anyone have an idea what would be causing the idel on my 2005 Series II XR6 Turbo Ute to be hunting up to 250 RPM once the car warms up? I have a CAPER box and tune but I have had that checked out and they say it is not the issue. Is it likely to be the Throttle Position Sensor? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 9d Gender: Male Location: Perth Posted 17/02/09 02:31 AM Share Posted 17/02/09 02:31 AM 1. Clean the throttle body with t/body/carby cleaner2. Check for air leaks in the intake piping3. Change your spark plugs4. Change your coil packs.5. Get the tune looked at by a decent tuner.(ihmo that the order i would go about sorting the problem out) Link to comment Share on other sites More sharing options...
dolbs Member 7 Member For: 17y 6m 26d Posted 17/02/09 06:00 AM Author Share Posted 17/02/09 06:00 AM Thanks for the info. Will do. Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 5m 4d Gender: Male Location: central coast Posted 17/02/09 06:15 AM Share Posted 17/02/09 06:15 AM mine used to hunt a little on idle ,and I need to check this more I have only drivin it once since , but I changed my battery for a high power one (oddysey ) and it idle's perfectly nowmaybe it was just because I had the battery disconected for a few hours and the pc lost some of it's learned programs or the battery is holding the voltage more stable and helping with idle Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 24d Gender: Male Location: Mildura Posted 17/02/09 09:04 AM Share Posted 17/02/09 09:04 AM (edited) refund your "CAPER" box and try a CAPA box??try cleaning the throttle body out, if that's not gunna work get the TPS errors checked, if the car does it, take it straight to ford and DONT TURN IT OFF or the error doesnt show, I had this problem years ago. Edited 17/02/09 09:05 AM by Trough Lolly Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 27d Gender: Male Location: Southern Highlands NSW Posted 17/02/09 09:20 AM Share Posted 17/02/09 09:20 AM ^ lol Link to comment Share on other sites More sharing options...
BTK_007 Member 25 Member For: 15y 7m 19d Gender: Male Posted 19/02/09 03:26 PM Share Posted 19/02/09 03:26 PM Mine does a wierd thing after being on idle for a couple of minutes. Recently it was just like a suction/vibration , more noticeable when ac was on, but tonight it actually turned off.... any thoughts? Link to comment Share on other sites More sharing options...
SubJimbo ŠύЂפֿĺmβø ™ Donating Members 1,216 Member For: 16y 9m 1d Gender: Male Location: Melbourne Posted 19/02/09 03:33 PM Share Posted 19/02/09 03:33 PM Follow hiddeous' steps mate, it should sort the problem, usually its the Throttle body, Use some carby cleaner and clean it out Should be all good after then! Link to comment Share on other sites More sharing options...
