  • Member For: 18y 9d
Re, Using ODBII coolant temps in these situations now can only high 60deg'sC which seems to low? Thoughts?
Too Low !!
Try to get a 85c unit for QLD.
I have been using a 88c here in Canberra for many years...
Very happy with it.
  • Member For: 14y 6m 23d
It seemed a bit low. Wondering if the coolant change just trigged a dodgy thermostat that now doesn't close 100%. Will look at a new one. Hopefully get quicker warm up temp too
Turns out the original thermostat wasn't closing up fully under its own spring. Interestingly it also had an additional hole as some others have found.
The rubber seal was pretty distorted with some calcium build up, its only 07 but perhaps 200,000kms it's excusable?
Went with an 82 hiflow. Hopefully quicker warm up and cooler loaded temps
Edited by Spoony
I did some tests a few years ago...
I found I get better Fuel Consumption with a 88c Thermostat than I would with a 82c Thermostat.
The Original 90c+ is / was too Hot.
Some interesting stuff:
http://www.tuneruniversity.com/blog/2012/04/low-temp-thermostats-whats-the-advantage/
I did actually wonder about this and fuel usage too. 92 is the 'stock' after market replacement option, there was only an 82 at Supercheap when I was there but perhaps 88 or whatever is a better option. hmmmmmm.
  • 2 weeks later...
  • Bronze Donating Members
  • Member For: 12y 13d
So it runs cooler when cruising? You want good economy when cruising so I would think standard is better. Bumper to bumper the coolant temp is same as standard and when boosting hard it is same as standard. Sounds pointless without a thermo fan setting change. Almost pointless all together. In saying that I am no tuner, and I don't see the difference on a lap top. Thoughts?
