Russ F6 Member 641 Member For: 20y 21d Gender: Male Location: Newcastle NSW Posted 11/02/09 09:22 AM Share Posted 11/02/09 09:22 AM Not sure, I wouldn't think so but I don't know. Wouldn't the fan just run longer and make it cooler?Russ Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-821190 Share on other sites More sharing options...
SAPNEN Donating Members 278 Member For: 17y 2m Gender: Male Posted 11/02/09 11:39 PM Author Share Posted 11/02/09 11:39 PM It would be ideal to have the fan come on earlier when the thermostat opens, but you don't have to change it...After a couple of days of boostn' I have learn't the new characteristics of the car with this thermostat:bumper to bumper - same temps as norm but takes longer to get hotboostn' hard - same temps as norm but takes longer to get hotCruisen - definately coolerI think if the fan were to kick in with the thermostat the bumper to bumper temps would definately stay lower than normal, and if you plan on circuit racing it would also be a good idea.Over all I think because of the way I drive (sometimes erratic, but then calm) the casual driving keeps the car running at a lower temp so when you put your foot down and give it a hard time it takes longer to heat up to the temps of norm where you will loose power...PS: If you do plan on circuit racing I would get a 77degC High Flow thermostat and drill 2 X 6-8mm holes on the outer edge and have the fan settings changed to kick in at 77degCHappy Boostn' Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-821469 Share on other sites More sharing options...
timbos99 Member 300 Member For: 16y 7m 29d Gender: Male Location: QLD Posted 26/02/09 12:19 PM Share Posted 26/02/09 12:19 PM (edited) I am in no way expert on this stuff but have read elsewhere about high flow thermos and drag racing, something along the gist of... The engine should run at a certain temp (hot), as the water cools the block/bore but the heat comes from piston so if it runs too cool, its a bad thing. that's why you don't drive hard til the engine heats up or else causes damage due to heat difference between piston and bore.High flow thermo is good for drag runs as the heat rises so quickly that the thermo doesn't get a chance to open and circulate water quickly enough thus overheats the bore. So high flow allows the water to circulate earlier and thus when that sudden explosion of heat kicks in run cooler.So not to poo poo the high flow thermo but just passing on something I read about years ago.... cooler is not necessarily better? Edited 26/02/09 12:22 PM by timbos99 Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-831590 Share on other sites More sharing options...
SAPNEN Donating Members 278 Member For: 17y 2m Gender: Male Posted 01/03/09 09:14 AM Author Share Posted 01/03/09 09:14 AM Makes sense... I guess it depends how you drive, this is why I opted for the 82degC and not the 77degC HIGH FLOW does not make a huge difference though. If you start drilling holes in the side of the thermostat then maybe...So overall there are issues here such as; Heater not as hot (for winter) Engine TOO cool for combustion chamber temp difference etc...It just comes down to if you treat your car nice... DON"T MESS WITH THE TEMP!If you drive hard, maybe consider doing this mod...And if you have a tune, check with your trusted tuner before making Thermostat changes.Its all up to you guys and how you drive... Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-833219 Share on other sites More sharing options...
XRPete Member 673 Member For: 17y 9m 24d Gender: Male Location: Here Posted 02/03/09 08:02 AM Share Posted 02/03/09 08:02 AM My tuner installed the 82 degrees one and adjusted the fans to suit and its all been sweet lately. I think your pretty safe with the 82 degree one. Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-833801 Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 8m 13d Location: Auckland Posted 21/06/09 11:03 PM Share Posted 21/06/09 11:03 PM I changed mine about 12 months ago and the car would not run properly. I changed it back and forth about three times and each time I put the 82 degrees one back in the car it would cough and splutter when under acceleration. I was told that I would need it tuned to adjust to the new thermostat. Don't know about other cars but this was the case with mine. Just a heads up if it happens to anyone else. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-894362 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 26d Gender: Male Location: OZ Posted 22/06/09 04:19 AM Share Posted 22/06/09 04:19 AM You also need to keep in mind that the spark calculation in these engines accounts for engine coolant temp. Ignition timing advance is not just as simple as having one reference from which the ecu reads. Spark calculation takes into account a number of factors such as air temp, coolant temps, commanded AFR etc etc. You change the coolant temp you change the spark. The final spark calculation is adjusted by the knock sensors anyway (for safety) but something to think about! Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-894462 Share on other sites More sharing options...
06TXR Donating Members 36 Member For: 19y 1m 3d Gender: Male Location: Ferny Hills Posted 19/07/09 07:06 AM Share Posted 19/07/09 07:06 AM I have had concerns over the amount of time my xrt was taking to reach operating temerature. The moment you start the car you can feel the radiator getting hot giving an indication that the thermostat is not closed properly. I made mention when the vehicle went in for its 3000k check over service and was told they found a sticking thermosat and replaced it. Car came back and sill not much difference. Made mention again on the 30k service as was told all was perfectly normal - the car was also shuddering bad when on the brakes and the advisor told when I was booking it in, it was because they were hot spotted from driving to hard. I challenged him to get down on the floor or get the car on a hoist and point out the hot spots on the car which he flat out refused and argued with me... Changed my "hot spotted" with not a mark on them this weekend to slotted ones with green stuff pads and decided to check the thermostat that was "perfectly ok" I noted that apart from the normal air bleed hole with the jiggler in it, there was another hole that had been drilled into it. Is this additional hole requred for some reason or anther on the XR6T engine? Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-908878 Share on other sites More sharing options...
CHLAXN Donating Members 932 Member For: 17y 1m 12d Gender: Male Location: north QLD Posted 19/07/09 07:32 AM Share Posted 19/07/09 07:32 AM not sure mate but my stock thermostat out of the F6 has the other hole too.. so I would not be worrying about that.. Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-908885 Share on other sites More sharing options...
06TXR Donating Members 36 Member For: 19y 1m 3d Gender: Male Location: Ferny Hills Posted 19/07/09 08:02 AM Share Posted 19/07/09 08:02 AM not sure mate but my stock thermostat out of the F6 has the other hole too.. so I would not be worrying about that..Thanks for reply. So you are using an aftermarket thermostat now? If you are, does it have the hole? Should we be putting this hole in the aftermarket replacements if they do not? It takes forever to reach operating temp - and for the heater to work! Link to comment https://www.fordxr6turbo.com/forum/topic/54429-82degc-thermostat-install/page/3/#findComment-908907 Share on other sites More sharing options...
