typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 11m 20d Gender: Male Location: Brisvages, Capalaba Posted 08/04/09 01:08 PM Share Posted 08/04/09 01:08 PM yeh I worked out where them lines went..turbo looks good on just nearly done with the surge and I will post up some pics Link to comment https://www.fordxr6turbo.com/forum/topic/54272-alternative-surge-tank/page/4/#findComment-857507 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 5m 16d Gender: Male Location: QLD Posted 08/04/09 04:05 PM Share Posted 08/04/09 04:05 PM Hay RIP85That .70 housing didn't give you anything over my .50 and I wasrunning a cheaper HDI cooler than your Huge cooler and I also sufferedFuel in the Top end as well and still I was quicker (Need Surge tank or lend of Tig Welder).Just a bit of rubbing in there LOL.typhoon Freak, yes tank needs to be verticle or top facing towards the front at a mild angle.Just think where the fuel will travell when under hard accelleration.Some Curcuit cars run scavanger pumps set up in 3 places, catchment at rear for accellerationcatchment to left for hard right handers and last catchment right hand side for hard left turns.that's why you usually hear of multiply pumps instead of just one big one.Some cars that just use 1 pump usually have a swinging pickup setup, so it goes where the fueltravels to, disadvantage is not being able to run full baffles or foam allowing weight shift.Unless you are going to go serious and race circuit the standard tank setup will be finewith surge tank at front. the taller the fuel reserviour the less chance of surge as well.Always try to have your fuel outlet from the surge tank at the rear because if your fuel doesdeplenish to much from the surge you may still lean out.this also goes for if you have the top angled back the fuel will try to go to the most rear pointunder accelleration and as in your picture the top rear would be the place the fuel would be best tocollect from under hard accelleration. Problem being once you stop accellerating it would become theworst place and only drawing fumes.that's why it is important on being verticle or at worst the top slightly angled towards the front of vehicle. Link to comment https://www.fordxr6turbo.com/forum/topic/54272-alternative-surge-tank/page/4/#findComment-857547 Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 11m 20d Gender: Male Location: Brisvages, Capalaba Posted 14/04/09 01:13 PM Share Posted 14/04/09 01:13 PM well iv made it and fitted it, I took the pics when the car was on the ramps so when its on the flat she aint that bad of an angle.. check em out n see what u think.. im no circut racer, I go to the drags occasonally so when I have a long weekend I shall attempt a better one and see what different ideas I can come up with. this was my first attempt.I think I did a pretty good job Link to comment https://www.fordxr6turbo.com/forum/topic/54272-alternative-surge-tank/page/4/#findComment-860745 Share on other sites More sharing options...
